Go to Post It never stops. Championships will be in your head forever!!! MWHAHAHAHA!!! - vadyr [more]
Unread 08-02-2014, 11:38
timetravel_1024 timetravel_1024 is offline
FRC #0839
timetravel_1024 is an unknown quantity at this point
Re: Positioning two connected motors
Hi DonRotolo,
Thank you for your reply! We are unable to use a Y cable because the rules state that we may only have one motor per controller for the motors we are using. However, we've decided to cut back to one motor in order to be able to use the built in CAN functions for positioning.
Unread 08-02-2014, 11:59
Don wasn't suggesting that you connect two motors to one controller.
He was suggesting that you connect two controllers to one DSC PWM port with a PWM Y cable. This is common and accepted practice.
Of course, if you did this you would have to connect the encoder to the cRIO (via the DSC).
Then, you would read the (single) encoder, use it to compute the appropriate output command (using PID or other control algorithm in your cRIO software), and send the computed command to the DSC PWM port... and the Y cable would send the signal to both motors.
I'm not sure if there's any accepted and field-proven way to use one Jag's built-in position controller to sync properly with a second motor.
Unread 08-02-2014, 13:47
I noticed that this new thread just got started.
