Re: CPP to Java
A "low-tech" solution if you are running something like a Raspberry Pi on the robot you could just use a digital output connected to the digital sidecar and the cRIO could just read that.
Re: CPP to Java
Where is the CPP video processing program being run?
(And what is CPP video processing?) |
Re: CPP to Java
To answer your first question the CPP video processing is run on a raspberry pi. To answer the second question CPP video processing is really opencv video processing. |
Re: CPP to Java
If all you really want is a yes/no signal, this sounds like a perfect way to satisfy the requirement.
