Re: How to attach hub to window motor
Last year we used the window motor with the hub mounted upside-down for our cam shooter. Obviously it would have been a problem if the hub on the motor had no firm grip so we just used superglue and it worked fine!
(but then you're probably left with a permanently attached hub ) |
In the past, we just would machine a plate that would sandwich with whatever the Denso motor would attach to. This however is a bit more work and machining a hole the size of the shaft holder can't be easily done without help from a machine shop unless you have a drill bit that big
