Go to Post [Bring] programmers [to Championships], they may be small, quite and easy to miss while leaving for Atlanta but its hard to do anything robotic without them, I've tried. - Simon Strauss [more]
Unread 08-02-2014, 13:06
Potatoes's Avatar
Potatoes Potatoes is offline
AKA: Eric Wittmann
FRC #5136 (Mecha Pirates)
Potatoes is an unknown quantity at this point
Question Ball Tracking
It's our first year as a rookie team and we have some questions about using a servo-mounted camera for ball tracking.
-Can we just use the example "2014 Ball Detection" code provided by FRC, and if so, how do we implement it into our own code?
-How would we calculate the trajectory of a ball mid-air? We could do the calculations and come up with the functions ourselves but it seems like a safer bet to use someone else's tried-and-tested code.
-Is there anything else I'm overlooking in terms of necessary pieces of code for using the camera to track ball movement?
Thanks in advance for the help!
Unread 09-02-2014, 12:07
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Re: Ball Tracking
As far as implementing the example, I would say re-make what you see in the example wherever you plan to do the calculation.
On trajectory, You may need to take the area and location of the ball for one image, then compare it to the area and location of the next image and the next one and the next one, each making these comparisons to get speed of the ball and/or possibly the direction.
Keep in mind your camera would have to be stationary for each image, limiting your movement however long you wanted to perform the calculation.
Per Audacia Ad Astra
Unread 09-02-2014, 16:14
killer_rabbit3's Avatar
killer_rabbit3 killer_rabbit3 is offline
programming rabbit
AKA: Alexander Martinez
FRC #1038 (Lakota Robotics)
killer_rabbit3 is an unknown quantity at this point
Re: Ball Tracking
You can import the ball track Project from examples into your robot project. I would recommend however to try and import it into your dashboard project and have the dashboard do the vision calculations on your computer as to not overload your cRIO.
Unread 11-02-2014, 22:03
Potatoes's Avatar
AKA: Eric Wittmann
Re: Ball Tracking
Now I have another question. How do I get the data that gets processed by the code running on my computer (the ball tracking project) about the ball's location to get sent to the dashboard running on the cRIO?
Is there a way to transfer variables/values from applications running on the cRIO to one running locally on my computer?
Unread 12-02-2014, 07:31
Re: Ball Tracking
The dashboard tutorial, and in particular tutorial 8 will explain one way to do it.
Greg McKaskle
