Go to Post Never should an idea be ridiculed, because ideas are exactly that just an idea. - Tim Delles [more]
Unread 08-02-2014, 15:57
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Ratchet Switch under load
Our team is trying to use a ratchet to release stretched surgical tubing (like I imagine a lot of teams are doing). We pull back our shooter using a winch and then shift into neutral so our motor shaft is no longer connected to the winch shaft. As the winch tries to unwind the ratchet holds it in place (ratchet acts as a hard stop).
The problem that we have however, is that nothing we have tried has been able to flip the ratchet's directional switch while it is under load. I have seen a couple other teams using this idea and so I am a bit confused as how they released the surgical tubing.
So to you other teams we are successfully releasing surgical tubing, how are you doing it under load?
