Go to Post Cheap is always a good thing, unless you are building a robot. - Francis-134 [more]
Unread 08-02-2014, 16:43
computronix computronix is offline
FRC #4638
computronix is an unknown quantity at this point
Smile Cannot turn on compressor programatically via Spike Relay
Hey guys,
We're having a lot of trouble getting the air compressor to turn on and regulate itself via a Spike Relay. Here's our setup:
  1. We have the DSC plugged into the cRIO and all three power lights are brightly lit
  2. The Spike Relay is plugged into the DSC on relay port 1 and the light is amber
  3. The pressure switch is also plugged into the DSC on DIO port 1
  4. The light on the Spike Relay does NOT turn green when it should be enabled, and the light next to the relay port on the DSC does NOT turn green when it should
Here is a link to our code, if you'd like to take a look. The compressor code is in the UpdatePressure class in the launcher package.
Any help would be appreciated. We've been working on this for two days with no luck. All we know is that the problem is between the DSC and the Spike Relay, but we can't figure out why.
Unread 08-02-2014, 16:57
ArzaanK ArzaanK is offline
FRC #1325 (Inverse Paradox)
ArzaanK is an unknown quantity at this point
Re: Cannot turn on compressor programatically via Spike Relay
We were having a very similar issue earlier.
Our problem is that our ribbon cable was not in correctly. If you are using a ribbon cable, make sure to screw down both ends, (in the cRio module and Digital Side Car). This fixed our issue for us.
Arzaan Khairulla
Programmer/Driver
2013 Greater Toronto Regional East Winners with 1114 and 2056
2013 Galileo Division
Unread 08-02-2014, 17:08
I would not put the compressor in a command. It's designed to run in the background automatically. I would declare the compressor in your launcher subsystem, and call start in the constructor of that subsystem. You don't need any other code.
Unread 08-02-2014, 17:56
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
You want this command to always run on the compressor so that it will always have full pressure and so that it will automatically shut off at the right time. To do this you need to set your UpdatePressure command as the default command for the compressor.
Here is an example from my team's code:
Compressor Subsystem
public class Compressor1 extends Subsystem {
    Compressor compressor = RobotMap.compressor1compressor;
    public void initDefaultCommand() {
        setDefaultCommand(new CompressorCommand());
CompressorCommand
public class  CompressorCommand extends Command {
    Compressor compressor;
    public CompressorCommand() {
        requires(Robot.compressor1);
    protected void execute() {
        if(!compressor.getPressureSwitchValue()){
            //Compressor NOT Full
            if(!compressor.enabled()){
                compressor.start();
        }else{
            //Compressor Full
            compressor.stop();
    protected boolean isFinished() {
        return false;
