Go to Post A good engineer will never stop learning. From his peers, technicians, and competitors. The field is just to vast for any one person to know it all. - Mr. Mike [more]
Unread 08-02-2014, 16:59
DarthCoder DarthCoder is offline
FRC #4309
DarthCoder is an unknown quantity at this point
PWM Input?
We need to be able to read a PWM input from a Radio Shack ultrasonic range finder. The PWM class only works for output, and we can't seem to get the counter class working either. Is there any way to read PWM from a digital input?
Unread 08-02-2014, 17:03
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: PWM Input?
Not through digital since it is on/off and the range finder would output multiple values other than 0 and 1, but you can through the analog breakout on the cRIO
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 08-02-2014, 17:05
FRC #4309
Re: PWM Input?
This is the one we have http://blog.radioshack.com/2013/07/f...-range-sensor/
We're pretty sure it's PWM not analog.
Unread 08-02-2014, 17:35
Re: PWM Input?
You are correct that it is a digital PWM input. However, it is also requires a digital output on the same pin to trigger a distance measurement. The cRIO FPGA wasn't designed to handle this use case. There are many other ultrasonic sensors that would be easier to use, including digital ones where the request and the response are on different pins. Alternately, you could build a circuit to separate the two signals.
Unread 08-02-2014, 17:57
Re: PWM Input?
I wonder if you could read the pulse width by treating it like a counter.
Oops... Maybe not with that part number.
Unread 08-02-2014, 17:59
FRC #4309
Re: PWM Input?
Tried that. It never returned anything but 0, and infinity. We even tested the counter with slower inputs and it worked that time. I think the sensor is too fast for the counter class.
Unread 08-02-2014, 18:27
Re: PWM Input?
The bottom of Page3 of the User's Guide for 2760342 implies that the SIG pin is a "Serial Monitor (9600)". Sounds like RS-232 to me, not PWM. Am I misinterpreting this?
Unread 08-02-2014, 18:33
Re: PWM Input?
I think that's talking about opening the serial monitor in the Arduino programming environment, so you that you can read the data that the Arduino code is sending over the serial port.
Here's the relevant portion of the arduino code for reading the sensor.
/*Begin the detection and get the pulse back signal*/
void Ultrasonic::DistanceMeasure(void)
    pinMode(_pin, OUTPUT);
	digitalWrite(_pin, LOW);
	delayMicroseconds(2);
	digitalWrite(_pin, HIGH);
	delayMicroseconds(5);
	digitalWrite(_pin,LOW);
	pinMode(_pin,INPUT);
	duration = pulseIn(_pin,HIGH);
Unread 08-02-2014, 18:47
Re: PWM Input?
Thanks Joe. I searched for a datasheet that documents the protocol of the SIG pin for this device but was not successful.
What I was looking for was this: Is the protocol strictly command/response, or can it be set up to continuously broadcast its distance measurements? And if so, is the pulse width user configurable into a range that the FPGA sampling rate could handle?
Unread 08-02-2014, 21:18
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: PWM Input?
Would not a counter count pulses rather than pulse width? It seems unless something is programed in the FPGA it is not doable.
Unread 08-02-2014, 22:38
Re: PWM Input?
The getperiod() method in the counter class in WPILib uses FPGA to measure the pulse width using a microsecond timer.
