Go to Post Can't we also care about and celebrate the processes, the professionalism, the experience of healing? - Taylor [more]
Unread 08-02-2014, 19:06
chigskonkwo chigskonkwo is offline
FRC #0884 (Mechanical Mules)
chigskonkwo can only hope to improve
Relay Solenoid vs. Double Solenoid? Double Solenoid Wired to Relay in DSC.
What is the difference between a relay solenoid and a double solenoid? Can regular double solenoids be wired to the relay in the digital sidecar if it is programmed this way, such as what is here where it says "Relay Solenoid Example" here?
http://team358.org/files/programming...2009-/LabVIEW/
Last edited by chigskonkwo : 08-02-2014 at 19:21. Reason: Obtained more information.
Unread 08-02-2014, 19:13
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Relay vs. Double Solenoid?
A relay, like a spike, is very different from a single- or double-acting solenoid.
If you're interested in the difference between single-acting and double-acting solenoids it's pretty simple: a double-acting solenoid is stable in whatever state it is in, whereas a single-acting solenoid always reverts to one particular state unless it is energized.
Unread 08-02-2014, 19:21
Re: Relay Solenoid vs. Double Solenoid? Double Solenoid Wired to Relay in DSC.
So what is meant here where they have "Relay Solenoid Example"?
Unread 08-02-2014, 19:29
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I'm no lab-view expert, but it looks like they're driving a solenoid with a relay (Spike) instead of the solenoid break-out-board. This was the only option before solenoid break-out-boards existed, and useful for driving multiple valves at the same time in the same direction.
Unread 08-02-2014, 20:40
12v solenoids can be run via Spikes (Relays in code) in place of using the Solenoid Module.
Only 12v solenoids can work this way.
Wiring goes like this for Single Solenoids:
Wiring like this for Double Solenoids (each solenoid block just represents one side of the Double Solenoid):
Unread 08-02-2014, 20:44
Oh okay, so just to clarify, there is no way to do this with 24v solenoids?
Unread 08-02-2014, 20:46
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Spikes will most likely fry if you try to run them off of 24v. You need to use the Solenoid breakout board.
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Speaking from personal experience, a Spike will blow up if powered with much more than 14V.
Unread 08-02-2014, 20:50
Oh okay thanks, it's just that we are experiencing problems with our Solenoid Module/Solenoid Breakout/Code/cRIO (we don't know what exactly the problem is) and are looking for any other way to power our solenoids.
Unread 08-02-2014, 20:53
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
There are some specifics about 24V solenoids in the 2014 manual, blue box on [R42] states a power limit for the solenoid breakout board, you should ensure that your solenoids aren't over-powering it.
Unread 08-02-2014, 21:05
The solenoids that we are using are the same solenoids that we used last year with no problem, with the same cRIO, Solenoid Module and Solenoid Breakout.
Unread 08-02-2014, 21:10
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Are you regulating your pressure properly? This year our solenoid did not work at all because we had our regulator set to over 100 psi versus the max of 60 psi.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 08-02-2014, 21:11
Our solenoids are not even being recognized by the cRIO/Module. None of the lights on the module are lit even before the compressor is turned on.
Unread 08-02-2014, 21:18
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Unplug the ribbon cable from the sidecar, and see if all three power lights on the sidecar are lit up.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 09-02-2014, 00:29
Which slot is your NI 9742 module installed in?
To help rule out hardware problems with the cRIO or the module, run one of the examples (e.g. Solenoid with Compressor). If the green LED on the module still doesn't light when you turn on the solenoid output, I suggest that you should talk to NI about getting a replacement.
That's good advice for problems controlling a Spike relay, but the Digital Sidecar is not involved at all in the problem being described here.
