Go to Post I owe these forums a lot more than $15 for all of the help and friends they have given me. - Karibou [more]
Unread 08-02-2014, 15:02
DarthMaulCIS DarthMaulCIS is offline
FRC #4607
DarthMaulCIS is an unknown quantity at this point
Case Structure
This is going into Teleop. I didn't use a Select block because I only want it to go Reverse when I push it. Would this accomplish what I want? Or am I breaking my robot?
Unread 08-02-2014, 15:05
Re: Case Structure
The way you have it now, it will always go in reverse, no matter whenther the button is pressed or not.
Unread 08-02-2014, 15:11
FRC #4607
Re: Case Structure
What do I need to do to change that?
Unread 08-02-2014, 20:52
Re: Case Structure
Change one of the cases (True or False) from "Reverse" to "Forward"
Right now both cases set the solenoid to Reverse.
BTW, a Select block can do the same thing.
Unread 10-02-2014, 17:57
FRC #4607
Re: Case Structure
But won't it go back to forward after I let go of the button?
Unread 10-02-2014, 18:39
Re: Case Structure
That's what your code does now.
It will revert when you let go of the button.
The Select is just a special 2-case Case.
There are easy ways to make the button toggle for either approach.
Unread 10-02-2014, 18:48
FRC #4607
Re: Case Structure
The toggle vi I found here
https://www.google.com/url?q=https%3...-XtvmfI_oiGQqA
Would that work? And I can code into periodic tasks a solenoid position switch without breaking the togglability right?
Unread 10-02-2014, 18:54
Re: Case Structure
That Toggle example would work fine, and it'll work in Periodic Tasks.
Unread 11-02-2014, 16:55
FRC #4607
Re: Case Structure
So if i have code in Periodic that resets the position to forward, the toggle will still work right?
