Go to Post geeez....and i was going to say they should knock a week off the build season. - johnr [more]
Unread 07-02-2014, 23:01
Wildcats1378 Wildcats1378 is offline
Wildcats1378 is an unknown quantity at this point
Waiting Until Limit Switch Is Pressed
Hello everyone!
So I am the programmer mentor and team lead for the Wildcats #3878 here in Hawaii.
I am writing a piece of code for our shooter that will continue moving a motor until it hits a certain limit switch, and then continues onto the next frame.
I am writing the code in an autonomous program as part of a flat sequence to $@#$@#$@#$@# the catapult to a set area based on limit switch, to determine the power of the shot we want.
How might this be accomplished?
Thanks everyone,
#3878 Head Programmer
Unread 07-02-2014, 23:14
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Waiting Until Limit Switch Is Pressed
Put it in a loop? I'm not sure how specific to get - depends on what framework you are using. Something like this..
while(limit input is not asserted and still in auto mode)
set motor speed
stop motor
Unread 08-02-2014, 00:14
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
I would recommend hooking the limit switch up to the Jaguar, so it automatically turns itself off. No code required.
Read the Jaguar's datasheet to determine how the limit switch functionality works and where you need to hook it up to.
Unread 08-02-2014, 00:51
Originally Posted by Wildcats1378 View Post
I am writing a piece of code for our shooter that will continue moving a motor until it hits a certain limit switch, and then continues onto the next frame...
You mentioned a flat sequence, so I assume you're using LabVIEW.
Just put a while loop in the frame, reading the limit switch inside the loop and using the returned value as the termination condition for the loop. It'll keep looping until the switch is activated. Be sure to also put a 10 ms delay (or thereabouts) inside the loop so it doesn't use up all the CPU cycles just waiting for the switch.
In this case, code is definitely required. This is a sequence of events that waits at one step until the switch is hit, so the program needs to be reading the switch.
Unread 08-02-2014, 22:05
tcjinaz tcjinaz is online now
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Is 10MS good enough to catch one of those switches with the lever arm and roller on the end? I am fretting about catching the signal in time to prevent arms slamming into supports.
I am almost wishing for interrupt driven controls here. Is there a way?
Tim
Software Mentor
3853 Pridetronics[
Unread 08-02-2014, 22:06
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
...flat sequence to $@#$@#$@#$@# the catapult...
Wow, CD really doesn't like for people to reload their launchers...
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 08-02-2014, 23:28
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
How far will the mechanism travel in 10ms? How quickly will the motor stop? And is that distance dangerous? In FRC, it is hard to imagine 10ms being too long for most any event-driven response but I would do the math.
HTH
Unread 09-02-2014, 00:42
Adamz_'s Avatar
Adamz_ Adamz_ is offline
Who wants coffee?
AKA: Connor Adams
FRC #4519 (Kings Mechavaliers)
Adamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to behold
i dont know what language your using, but in java it would look something like this
if(!limitSwitch.get()){
   motor.set(1.0);
 }else if(limitSwitch.get()){
   motor.set(0.0);
in englsih all this is doing is saing, if the limit switch if false (not pressed) spin the motor, then in the else if statement, it checks if the limit switch is true (pressed) and if it is, it will stop the motor, if you want it so once its in this state, you press a button to shoot, the code would be this;
   motor.set(1.0);
   motor.set(0.0);
 }else if(controller.getRawButton(1)){
  motor.set(1.0);
2016 North Bay Regional Finalists
2016 Greater Toronto Central Regional Semi-Finalists
2015 Windsor Essex Great Lakes Regional Quarter-Finalists
2014 Windsor Essex Great Lakes Regional Semi-Finalists
2014 Waterloo Regional Quarter-finalists
2013 Waterloo Regional Highest Rookie Seed
2013 Waterloo Regional Rookie All Star Recipient
Unread 09-02-2014, 00:45
When we're worried that we might miss a brief switch input between samples, we open the input as a counter instead. Then we watch for the counter to change values, and that tells us the switch was hit.
If something pulses quickly enough to be missed by the FPGA, we've already got some re-engineering to do.
Unread 09-02-2014, 09:14
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
This is as much a question of programming as it is of limit switch positioning.
It's often easier to modify the limit switch position to solve end position problems like this.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 09-02-2014, 13:52
I would be less worried about detecting the limit switch as I would stopping a fast moving part with a lot of inertia. Programming can only minimally impact the latter.
