Go to Post I love it when someone tells me I can't do something. - dlavery [more]
Unread 08-02-2014, 10:36
E, Palmer E, Palmer is offline
FRC #6239 (The Irrational Engineers)
E, Palmer will become famous soon enoughE, Palmer will become famous soon enough
CPP to Java
My issue is that my programming team has written our video processing program in CPP. However our robot and smartdashboard are written in java.
We need to send a Boolean from our video processing to our autonomous program. I do not know how to convert the CPP Boolean to a java program. Any help would be awesome.
Unread 08-02-2014, 10:49
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Re: CPP to Java
What do you mean smartdashboard is written in Java?
You can always reimage the cRIO to C if that is what you mean by "robot written in java".
Unread 08-02-2014, 11:09
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
Re: CPP to Java
The chunk of data which is the boolean doesn't have to be converted to a "Java program". For sending some data from the Driver Station to the robot, one could use sockets.
Basically, one opens a UDP socket on the Driver Station side and sends the data through. The robot side should have a UDP socket open and bound to some port like 1130 to which the Driver Station app is sending. I would recommend sending a character for something like that rather than a boolean since there isn't a defined format for booleans.
Unread 08-02-2014, 11:51
Re: CPP to Java
The JVM used for java on the cRIO doesn't support UDP, so TCP would have to be used for this approach.
Unread 08-02-2014, 12:30
Re: CPP to Java
Sorry if I was unclear. All of our dive code/autonomous is in Java so the crio is flashed to java. We are using the Java smartdashboard.
Our autonomous program needs to know if the goal is hot or not. The video processing will tell us that . So I need to send a Boolean between the CPP video processing to the Java autonomous telling whether the goal is hot or not.
Unread 08-02-2014, 12:33
MoosingIn3space MoosingIn3space is offline
Programming Division Captain
FRC #3334 (Eagle Robotics)
MoosingIn3space is an unknown quantity at this point
Look at Boost.Asio for sending data. Use a threaded socket communication layer to keep a connection open continuously so you can receive TCP messages from the C++ program.
Unread 08-02-2014, 12:54
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
Re: CPP to Java
A "low-tech" solution if you are running something like a Raspberry Pi on the robot you could just use a digital output connected to the digital sidecar and the cRIO could just read that.
Student (3309) 2010-2013
Mentor (597) 2014
Mentor (3309) 2013-Present
Unread 08-02-2014, 23:02
Re: CPP to Java
Where is the CPP video processing program being run?
(And what is CPP video processing?)
Unread 09-02-2014, 17:40
Re: CPP to Java
To answer your first question the CPP video processing is run on a raspberry pi.
To answer the second question CPP video processing is really opencv video processing.
Unread 09-02-2014, 21:46
Re: CPP to Java
If all you really want is a yes/no signal, this sounds like a perfect way to satisfy the requirement.
