Go to Post Wins = Attention Attention = Sponsors Sponsors = Money Money= being able to do more. a vicious cycle...but it is what it is - Protronie [more]
Unread 09-02-2014, 01:14
IVAN IVAN is offline
FRC #2429
IVAN is on a distinguished road
2429 scouting doc 2014
Here is my rough draft of our scouting spread sheet for this year. This one is currently set up for IE. Thoughts? If your looking for how I did the math it its at the bottom of the team sheets. Also since we don't have match schedules yet the match sheet isn't done
Unread 09-02-2014, 13:36
FRC #2429
Re: 2429 scouting doc 2014
ill do my best to answer any questions ya'lls might have
Unread 20-02-2014, 01:16
FRC #2429
updated paper accidentally forgot about the one pointers
also to be able to keep the shooting avg for the one pointer accurate you must input both made shots and missed shots as decimals into the main shooter tab
also id love some feed back on what y'all think and if your team is thinking about using the sheet or a modified version of the sheet
Unread 20-02-2014, 15:10
depth_Finder's Avatar
depth_Finder depth_Finder is offline
I am the one who graphs
AKA: Quinn Schiller
FRC #1983 (Skunk Works)
Team Role: Tactician
depth_Finder is a splendid one to beholddepth_Finder is a splendid one to beholddepth_Finder is a splendid one to beholddepth_Finder is a splendid one to beholddepth_Finder is a splendid one to beholddepth_Finder is a splendid one to beholddepth_Finder is a splendid one to behold
Wow. This is a lot of work. I congratulate you guys. Did you look at using Pivot Tables?
Check out my tutorials at http://www.tableausoftware.com/first-robotics
Unread 20-02-2014, 21:48
FRC #2429
no I haven't looked into the pivot tables, though my team may be able to use them in later years. though my issue with what i've seen of pivot tables wouldn't allow me to do the compiling set up I currently have to only calculate per match entered
Unread 22-02-2014, 02:25
FRC #2429
had a couple of errors in both Excel and some changes to be made in word so here they
