Go to Post Back in the old days, we didn't have clues, and we liked it! - Joe Ross [more]
Unread 09-02-2014, 01:27
Willyspu Willyspu is offline
AKA: Jim
FRC #2144 (Gators)
Willyspu is a jewel in the roughWillyspu is a jewel in the roughWillyspu is a jewel in the roughWillyspu is a jewel in the rough
Ending The Round Loaded
Since many of teams are building catapults with fairly high powered and dangerous ball launchers with lots of surgical tubing etc. what safety precautions are your teams taking if your robot ends a round while your catapult is pulled back in the "cocked" or "loaded" position?
We are looking are making a safety device or clamp for our team to restrain the catapult if it ends loaded at the end of the round.
Is your team working on something to make it safe to move your robot if your robot ends a round with the launcher ready to fire?
Unread 09-02-2014, 01:30
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Ending The Round Loaded
Single acting pneumatic solenoids can be used to trigger safe settings as power is cut.
IVAN IVAN is offline
FRC #2429
IVAN is on a distinguished road
if you are using the ratcheting gearbox concept the back side of a hammer does a good job of pulling out the shifter block on the andy's
Unread 09-02-2014, 02:00
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
In addition to the built-in safety features on the robot, we'll be clipping carabiners through parts of the shooter and the shooter frame to lock it out during transport and storage.
Unread 09-02-2014, 14:19
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
So your shooter fires every time you disable or cut power? That's hardly safe in the pits, or when testing.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 09-02-2014, 14:28
raptaconehs raptaconehs is offline
FRC #3200
raptaconehs will become famous soon enoughraptaconehs will become famous soon enough
Actually a single acting pneumatic piston will only fire on command. There is a spring that will force the piston back down to a resting position after each shot.
Unread 09-02-2014, 14:36
Joe G.'s Avatar
AKA: Josepher
No, should have clarified. It relieves the system of any built up tension when power is cut, rather than actually firing. Auto-fire on disable would be unsafe for a number of reasons.
Unread 09-02-2014, 14:37
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We have a few safety features, both in software and hardware. Most of these aren't unique to this year.
Software:
-We have incrementally (over the past few years) adding 'ok to actuate' (OKTA) signals in addition to the command signals for actuators. This year we've added them for all solenoids. Part of the output layer (in code) takes a boolean position for the solenoid and a boolean OKTA for the solenoid, and then the output layer takes care of dual vs single coil, safe states during OKTA, and polarity inversion.
-We also added OKTA signals for several control loops this year. A negative setpoint (since all of our setpoints are in the positive region) will trigger the control loop to hold the integrator in reset and hold the output to 0.
-We have a boolean signal in code called 'reinit' which is triggered every time we exit disabled mode, and it forces all the code into a 'safe' state. All of the state machines to go a 'default' or 'manual' state which sets all of the actuators to 'not OKTA'. The user must command another state for the actuators to go OKTA (usually all of them commanded by that system go OKTA at once, which is acceptable to us).
--For this year, we used several dual-coil solenoids vs single-coil solenoids for safety reasons as we did not want actuators moving when we disabled the robot. We also used a single-coil solenoid for similar reasons.
Hardware:
-We are planning on building a metal bar with features which latches between parts of the robot, preventing it from firing. This would be removed when the robot is set on the field
-We will release the stored energy between competitions and overnight.
Kettering Motorsports
Unread 09-02-2014, 15:39
AKA: Jim
FRC #2144 (Gators)
This sounds like a great idea especially for the team members that need to quickly (and) safely retrieve a loaded and ready to fire robot from the playing field!
Jim
Unread 09-02-2014, 17:48
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
We designed a catapult that can only fire when the robot is active. When disabled the stored energy (compressed air) simply vents to atmosphere. The same thin happens when we are active too. If we decide not to shoot, the system will vent and release all tension in the entire mechanism. The only time pressure is stored in the shooter is when the operator holds down the trigger.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 09-02-2014, 21:58
bowmanb bowmanb is offline
AKA: Bruce Bowman
FRC #3991 (KnightVision)
bowmanb is an unknown quantity at this point
We've also incorporated locking pins in our mechanism with big red "REMOVE BEFORE FLIGHT" streamers attached.
