Go to Post The Robot Alliance Project is perpetrating the government shutdown? I KNEW robots would take over the world! - BBray_T1296 [more]
Unread 09-02-2014, 01:31
GortGortGort's Avatar
GortGortGort GortGortGort is offline
AKA: Lee Cole - Mentor
FRC #5040 (The BoltBots)
GortGortGort has a spectacular aura aboutGortGortGort has a spectacular aura about
Any Wicked Awesome Goalies out there ?
We were just wondering it seems everyone is building ball shooters are there any wicked awesome goalies out there ? Are any teams building high goal or low goal blockers ? It seem a blocking bot would be rather a sought after commodity ?
Unread 09-02-2014, 06:34
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
It seems like you could block the low goal by just sitting in front of it.
Unread 09-02-2014, 09:10
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Any Wicked Awesome Goalies out there ?
There are 3 entrances into each low goal. A good low goal defender will need to do far more than "sit in front of it"
___________________
- Tennyson, Ulysses
Unread 10-02-2014, 07:04
Our team has noted that most catapult and puncher shooting bots seem to only be able to hit the high goals and the top entry of the low goal . So we have concentrated on a blocker for these two areas . Has anyone else noticed this phenomenon also ?
Unread 10-02-2014, 22:05
BethMo BethMo is offline
FRC #0948 (NRG (Newport Robotics Group))
BethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to behold
During brainstorming someone suggested a goalie bot four feet long (possibly with a 20" extension that pops out at each end) by eight inches wide, 60" tall, and a drive system allowing it to speedily move sideways. Along the top would be a line of pneumatic pop-up blockers, which the operator controls with something like a piano keyboard.
Of course, this would completely block one driver's view if it wasn't made see-through. This led to speculation about an anti-goalie bot whose main strategy would be to block the opponents view, and whether such a monstrosity would violate gracious professionalism.
Unread 10-02-2014, 22:09
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
I think most people are over 5' unless the extensions somehow build a wall
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
Unread 10-02-2014, 23:06
stufflikethat stufflikethat is offline
stufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of light
Due to the rule about the 6 inch cylinder going above 5 feet i can't imagine how hard it is to be a good goalie.
Though if simbotics, robonauts or one of those other fantastic teams build a goalie that doesn't allow the opposing alliance to score they will obviously win.
Only time will tell though.
Unread 10-02-2014, 23:17
Ryan Caldwell's Avatar
Ryan Caldwell Ryan Caldwell is offline
217 Alum, 2851 Mentor
FRC #2851 (Crevolution)
Ryan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant future
Send a message via AIM to Ryan Caldwell
Sounds like it would end up on its side allot... definitely pushed out into open field to try not to fall over as soon as possible in a match.
Insane and Insight are just about the same thing if you squint and turn your head ever so slightly
Unread 10-02-2014, 23:42
I think you might want to re-read the rule on the blocking there is no height rule:
If a ROBOT is in contact with carpet in its GOALIE ZONE, and for only one ROBOT per ALLIANCE at a time, there is no height restriction; however, any extension or combination of extensions above 5 ft. may not extend beyond a vertical cylinder with a 6 in. diameter.
Our high goal blocker can zip up to 112 inches and can withstand the blunt force of the direct hit of the ball with out toppling over the robot. We are new to this being a rookie team .
The team just wanted to be good at one thing blocking shots.
In the hope that we were a valuable asset .
Unread 11-02-2014, 01:40
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
From my experience, being offensive wins matches more often than being defensive. I've found that acquiring more points for your own alliance is much more valuable than preventing the other alliance from scoring. The bottom line is that offense scores points, and defense does not. Teams like 1114 and 118 are aware of this, and may be too busy during a match scoring assists and goals, that they need not bother with being a goalie. I do see a possibility, though, of a high performance team choosing a good goalie robot -- that ideally can also score in the low or high goal and can do controlled assists -- as an alliance pick.
Unread 11-02-2014, 06:28
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
I beg to differ. See Super Bowl XLVIII.
Defense is unappreciated because it's value is not directly apparent in the score.
Preventing or delaying a cycle is the same as scoring.
Unread 11-02-2014, 06:50
SpongeBobby SpongeBobby is offline
AKA: Mr. Tubs
no team (Team)
SpongeBobby is an unknown quantity at this point
Being that each offensive team has only one ball, a good defender might be the winning teams mvr (most valuable robot). This year defense in a one on one matchup.
Unread 11-02-2014, 07:58
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
This is absolutely true! A perfect example of this (in FIRST) would be at the Pinetree regional. My team was selected by the top rank alliance 3467 and 2648. The matches were going well and we found ourselves in the finals. Match one went great (we won), then match two came along and just before the match started an inspector noticed something that was wrong with our robot that they had missed on the last two inspections causing us to have to sit on the field disabled for the match. Unfortunately this caused us to lose the second match and go into the dreaded third match of the finals. By this time we had fixed our bot and were back up and running. The third match came, we played our hearts out and came out on top for a well deserved title as the regional champions.
So moral of the story? Defense really does help. All 2386 was able to do was defense and score in autonomous. By us not being able to compete match two and losing by over 50 points (we were usually 50 ahead), showed just how valuable our defense was. We were quite pleased with how us not being able to play in match two, showed that we hadn't just won a lottery, but we actually greatly helped our alliance in getting to where it did.
Defense is totally underrated.
Unread 11-02-2014, 08:18
Akash Shah's Avatar
Akash Shah Akash Shah is offline
FRC #4954 (4-H Palindrome Robotics Club)
Akash Shah is an unknown quantity at this point
Defense is totally underrated. I can see that defense will be a major part of the game after the ball is passed to your alliance member. You will have nothing else to do while you wait for the robots on your alliance to score for the next ball to be put into play. So I can see defense becoming a big part of the game after these week 1 competitions coming up.
FIRST Robotics Competition Team 4954
Co-Lead Mentor/Alumni
Drexel University Class of 2019
Unread 11-02-2014, 08:21
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
ohrly? is an unknown quantity at this point
My team put a LOT of consideration into the idea, but ultimately the mentors vetoed the dedicated goalie.
You can find an animation here: http://www.youtube.com/watch?v=408YXf6kGJ0
The idea is up for grabs if you can build it in a week...
PM me if you want a detailed .blend file.
