Go to Post I guess we're going amish this year. - Jon Anderson [more]
Unread 09-02-2014, 01:37
sasha831 sasha831 is offline
Sasha
FRC #4529 (AI Robotics)
sasha831 is an unknown quantity at this point
Unhappy Axis Camera Black/White Vission Processing
Hello All,
Last Year our team used labview, and in our attempts at locating the vision targets, we set the camera to black and white.
However, This year we want to use the sample java code for vision processing, and as far as we can tell, this requires the camera in colour.
We have checked through all the settings when assessing the camera though the browser, and the only slightly related setting that we could find was the colour slider, which was set at 50, and absolutely nothing changed when we changed that to other values(0, 25, 75, 100). We have also tried resetting the camera, which seems to have changed nothing...
Any Suggestions? Or Is it possible to use the provided example with a black and white image?
Sasha
Theory is when you know everything but nothing works. Practice is everything works but no one knows why. On our Team, theory and practice are combined: nothing works and no one knows why!
Unread 09-02-2014, 01:49
Zmarken Zmarken is offline
FRC #1716 (Redbird Robotics)
Zmarken is an unknown quantity at this point
Re: Axis Camera Black/White Vission Processing
According to this and the manuals for the Axis M1011 and M1013, the image will only be displayed in black and white if the Color Level setting is at 0.
Which camera are you using, by the way? That would help a bit. And as far as I can tell, if the Color Level's set above 0, the camera'll be in color. So maybe the settings just haven't been applied to the camera for some reason?
Unread 09-02-2014, 01:58
Sasha
Woops, forgot to mention the camera Its a M1011. The color is set to 50 and has definitely been set multiple times. I believe that in our labview code we ran a function to set it to black and white? Maybe someone's heard of something like that and a way to undo it...
Unread 09-02-2014, 02:35
I don't have a camera on me right now, so I couldn't check, but could the NI Vision Assistant have something to do with it? It couldn't hurt to look at it at least.
Unread 09-02-2014, 08:30
The VAPIX API, which is what the Axis cameras respond to, lists a property called ColorEnabled. That property causes the camera to return a monochrome JPEG. It will be smaller and may decompress faster.
This differs from setting the color level to zero. A color level only affects how saturated the image is. You'll still get a color image, but with little or no color in it.
I don't know if the Java libraries include ColorEnabled, as it is rarely used.
Greg McKaskle
Unread 09-02-2014, 08:57
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
One approach to consider is resetting the camera to factory settings, and then applying only the changes you are interested in. Doing so eliminates any mysterious changes someone in the past might have made, and allows you to configure another camera the same way (e.g., at the competition, your camera breaks, and you borrow one from someone else)
Page 42 of the manual (http://www.axis.com/files/manuals/um...40_en_1203.pdf) describes how to reset to factory settings.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 09-02-2014, 13:24
yash101 yash101 is offline
AKA: null
It's better to threshold a colored image into a binary image. That way, you can filter colors!
