Go to Post Teamwork, dedication and friendship have a lot of play in all factors of life, including a robot contest. - tenthirtythree [more]
Unread 09-02-2014, 11:28
Thorn Thorn is offline
None #2869 (Regal Eagles)
Thorn is an unknown quantity at this point
Macanum Drive Train Problem
My team purchased the upgrade kit from AndyMark.
The motors are not all turning at the same speed. There is no driving the robot straight without a programming hack because maximum power on the wheels results in different RPMs for different wheels.
There was a long wait on back-order, and now as we enter the final week it is very stressful to not have a working drive train.
I think the problem is the connection to the gear boxes, but it's difficult to see exactly what is wrong and how to fix it. Has anyone seen this issue before? How can we resolve this?
Unread 09-02-2014, 11:32
Justin m's Avatar
Justin m Justin m is offline
FRC #2028 (Phantom Mentalists)
Justin m is an unknown quantity at this point
Re: Macanum Drive Train Problem
Hello,
Even though I was not on the team when we last did mecanum drive, I heard that encoders are necessary for the RPM, as every motor is different and will give differing RPM s at the same voltage
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
We had this issue, turns out somehow our students ended up using a screw that was too long between inside the gearbox and the CIM Motor. When this happens, the caps lift up slightly. Check to make sure this is not happening.
Make sure you grease the geatboxes.
What sort of motor controllers are you using?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 09-02-2014, 11:34
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
My team's programmers were thinking the same thing with our system. The real reason is that your center of gravity is not perfectly in the center of the robot so the weight on each wheel is different. This causes certain wheels to push more than others. If you are not at the weight limit, it might be worth it to add weight to get the center of gravity in the center of the robot.
Unread 09-02-2014, 11:38
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Would it be possible to post a picture of your set up? 449 used the toughbox nano's with 6" mecanum wheels and had no problems what so ever.
Do all of the gearboxes have the same internal gearing and the same total gear ratio? The kit seems to have a 12.75:1 ratio while if you buy each gearbox individually they could have a 10.71:1, 8.45:1, or 5.95:1 ratio.
Are all four of your drive motors normal cims and one isn't a mini-cim?
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 09-02-2014, 12:45
Thank you all for you your feedback, but I'm afraid most of the obvious ideas have already been checked.
We are testing the wheels now with no weight on them at all. I can easily tell by looking at the wheels that they are not spinning at the same rate. All gear boxes came from the Andy Mark upgrade kit so they all should have the same ratio (all the gear boxes do look identical inside). We did grease the gear boxes.
We are using Jaguars. My feeling is that the problem is mechanical rather than electrical. We aren't using the Mecanum drive code (with the Java WPI Lib) right now, we are just running full power to the motors or whatever we get from joyStick.getY() input.
Here are a couple of pictures for reference:
top view of control system
Wheels without wires
Do Jaguars sometimes develop an issue where 100% power really means 80% power because the Jaguar is failing?
Unread 09-02-2014, 12:50
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Try rotating the wheels by hand. If any of them are harder to turn, you may have overtightened the bolts going into the axles. We had a similar issue caused by that.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 09-02-2014, 13:03
PVCMike PVCMike is offline
AKA: Mike Jr.
FRC #1058 (PVC Pirates)
PVCMike has a spectacular aura aboutPVCMike has a spectacular aura aboutPVCMike has a spectacular aura about
It's asking a lot in my opinion to expect that they all output the exact same torques and speeds at a given current. We've run mechanum drives many times. In the past, we've used encoders, gyros and accelerometers to combat the issue of varying wheel speeds. They all proved pretty effective in measuring these variations and sorting them out electronically.
From a mechanical standpoint, I would definitely (with the robot off) give the wheels a spin with your hands to make sure the resistance is relatively the same on all 4 wheels. Also make sure all of your electrical connections are good and tight and that you're getting equal output voltage to each motor.
Coming up on year 15 with the PVC Pirates!: www.team1058.com
https://www.thebluealliance.com/team/1058
Unread 09-02-2014, 13:13
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Have you calibrated the Jaguars?
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
