Go to Post Please understand that teams run things differently for specific and very valid reasons. And, this is OK as long as the students are inspired. - Alexander McGee [more]
  #40   Spotlight this post!
Unread 09-02-2014, 14:15
Re: BatteryBeak: Utility of making internal resistance and state of charge measuremen
I believe you are correct that the 3 terminals are hi, lo, and ground. Connect the battery thru your ammeter1 to two of the terminals and measure amps. Whichever gives you closest to 3 amps is what you want.
You can measure the volts periodically if you wish. Use the manufacturer's published discharge curves as a reference for what the voltage should be2 as time progresses. If the battery voltage drops well below where it should be, you can stop the test - the battery is weak. If you're getting good readings and you stop the test too soon, you may get a false result - you may think the battery is OK when in fact it is not.
WEAR SAFETY GLASSES and FOLLOW ALL SAFETY PROCEDURES.
1 make sure the ammeter is set to 10 amp (or more) scale or you risk burning it up.
2 ask if you need help deciphering the curves
