Go to Post "Your really pretty and I like your bot" - prettycolors91 [more]
Unread 09-02-2014, 14:35
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Re: First Programming - Victor/PWM help
Here are some pictures. One is of all our PWMs that were connected to the Victors. As far as I can tell it doesn't seem like they're bent. The second one showing how far the PWM is going into the slot on the Victor.
Do these look incorrect?
I'm going to attempt to describe plugging them in, it feels like the pushing the cable goes through two stages. The first is actually finding the holes so you wiggle it a little until you feel that the pins are fitting into their holes. The second is pushing them in further into the holes and there is a little more resistance when pushing them in and it feels like they're getting more secured.
ID:	16184  Click image for larger version
I am an employee of FIRST. However, the postings on this site are of my own perspective as a FIRST mentor and volunteer and do not necessarily reflect the views of FIRST.
FIRST Team 5125 Hawks on the Horizon Lead Mentor
FRC Team 4096 Ctrl-Z Former Mentor
FTC Team 5203 #19@! Former Mentor
FRC Team 1403 Cougar Robotics Alumni
Unread 09-02-2014, 15:03
Originally Posted by popnbrown View Post
Here are some pictures....
What checks have you done to determine that you are actually delivering a signal to the Victor end of your PWM cable?
Unread 09-02-2014, 15:11
popnbrown's Avatar
AKA: Sravan S
We've gone through code to ensure we've got the correct PWM Channels being assigned, however we can't probe any of the WPI Libraries deeper (it just won't let us).
As far as hardware, ensure that the Victor and Digital Sidecar are getting power. It's difficult to use a multimeter and see what the readings of the actual PWM cables are but we've tried and it seems as though it's not putting out any power (signal) through the cables.
Other debugging steps have included trying different PWM Channels and PWM Cables, we have yet to try different Victors, but it doesn't seem like a Victor issue.
-Sravan
Unread 09-02-2014, 15:13
Do you have access to an oscilloscope?
Unread 09-02-2014, 15:32
popnbrown's Avatar
AKA: Sravan S
Unfortunately, no.
I just checked with the multimeter again and just poked around (literally) in different ports on the Digital Sidecar. There's 6V from the V+ to the black on the PWM out ports. 0V between Sig and (-). 0v between Pwr and (-). On the Digital IO, however, 5V between Pwr and (-).
Any suggestions Ether in troubleshooting without an oscilloscope?
Unread 09-02-2014, 15:35
Do you have a known good Talon or Jaguar?
Give it some 12V power and plug your PWM cable into it. See what the LED does.
Unread 09-02-2014, 15:39
When you are issuing a "full throttle" (forward) PWM command, you should have a duty cycle of approx 20% (2ms pulse divided by 10ms period). So your multimeter should read roughly 1 volt across the white (SIG) and black (return) PWM wires. Use the DC setting and observe proper polarity.
Unread 09-02-2014, 15:54
popnbrown's Avatar
AKA: Sravan S
Yup...I removed all the PWMs and checked them, it's giving a 0.75 volt reading in neutral. So it's working correctly.
