Go to Post I know that it's often dangerous to use common sense in a YMTC thread... - Kris Verdeyen [more]
Unread 09-02-2014, 14:53
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Jaguar Failures
We have managed to have 4 Jaguars that have failed. This is quite unusual for us. We have used Jaguars since the first year they were available (5 years?). This is the first time we have had this many failures.
The failure mode is that the Jaguar goes dark, no lights. When I hook the Jaguar to a variable power supply, the supply is unable to provide current to the Jaguar, indicating a short on the power supply side.
Inspection doesn't show any obvious signs of failed components.
I believe the failed devices are models from previous years before the conformal coating change. Debris is a distinct possibility, but I would hope that the device would recover once the debris is removed.
I'm looking for suggestions for diagnosing the problem, preventing additional failures, and potentially recovering these devices.
Thank you for you suggestions.
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 09-02-2014, 15:21
Re: Jaguar Failures
Originally Posted by duane View Post
I believe the failed devices are from years previous to the conformal coating change...
Just to be clear: these particular Jags were working this season, and then they failed?
Unread 09-02-2014, 15:58
duane's Avatar
Re: Jaguar Failures
Yes. The Jaguars have been working for quite a while. Then they failed.
Thank you for asking.
Duane Murphy
Mentor - Software
Unread 09-02-2014, 16:09
Re: Jaguar Failures
Even though these are older Jags, I suggest that you contact VEX support and let them know what happened. It's possible they may ask you to send the Jags to them for failure analysis.
Unread 09-02-2014, 22:31
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: Jaguar Failures
We've seen lots of problems with older firmware a Jags not putting up with rapid reversals of direction due, I assume to back EMF and huge current spikes. A year or two ago TI (pre VexPro) did a firmware update that included some fast automatic ramping. We had given up on Jaguars by then so I'm not sure if that fixed it. We always ramp our speed controllers in software now to avoid huge current spikes.
