Go to Post the bang for the buck is unparalled. Where else can $6000 change an entire group of student's lives forever? - Cory [more]
Unread 09-02-2014, 17:42
PANTHERPROJECT's Avatar
PANTHERPROJECT PANTHERPROJECT is offline
FRC #2064 (The Panther Project)
Team Role: Webmaster
PANTHERPROJECT will become famous soon enoughPANTHERPROJECT will become famous soon enough
Re: Programming Mecanum
Originally Posted by nyaculak View Post
I think you instantiated your RobotDrive instance with the motors in the wrong order. Correct me if I'm wrong, but the order should be frontLeft, rearLeft, frontRight, rearRight. Try changing the instatiation to
RobotDrive drivetrain = new RobotDrive(1, 2, 3, 4);
If that doesn't work, try as others have suggested and mount the robot up on blocks to isolate the wheels. This helps tremendously in debugging a faulty drive train.
That is how I instantiated it originally. When I did that, the wheels moved forward, backward and rotated but did not move side to side.
