Go to Post "Oblivious" people asking questions are what gives us an excuse to sit around on CD. - Ryan M. [more]
Unread 09-02-2014, 17:52
silas13579 silas13579 is offline
FRC #2337
silas13579 is an unknown quantity at this point
Re: Problem connecting to the CRIO
So far, connecting directly to the CRIO actually has been working, so we're just going off of that right now. The bridge config utility isn't working on our radio. It says login failed.
Unread 09-02-2014, 18:25
Zmarken Zmarken is offline
FRC #1716 (Redbird Robotics)
Zmarken is an unknown quantity at this point
If deploying directly through the cRIO is working, then I'm pretty sure it's a router issue.
I'd say you should do a factory reset of the router, then go through the Bridge Configuration tool again. If you're using the router in the KoP, reset it by holding down the reset button in the back of the router for ~10 seconds.
Try that, and see what your results are.
