Go to Post I think if you talk with mentors of FIRST teams, you will find that they have changed the world. - Bill Moore [more]
Unread 09-02-2014, 18:25
Zmarken Zmarken is offline
FRC #1716 (Redbird Robotics)
Zmarken is an unknown quantity at this point
Re: Problem connecting to the CRIO
Originally Posted by silas13579 View Post
So far, connecting directly to the CRIO actually has been working, so we're just going off of that right now. The bridge config utility isn't working on our radio. It says login failed.
If deploying directly through the cRIO is working, then I'm pretty sure it's a router issue.
I'd say you should do a factory reset of the router, then go through the Bridge Configuration tool again. If you're using the router in the KoP, reset it by holding down the reset button in the back of the router for ~10 seconds.
Try that, and see what your results are.
