Go to Post If you have to build the best robot to be inspired then we end up with one winning inspired team, and 999 losers. That is not the spirit of FIRST. - KenWittlief [more]
Unread 09-02-2014, 19:44
alexander.h's Avatar
alexander.h alexander.h is offline
Lead Programmer, Captain, Driver
FRC #3975 (The Dragons)
alexander.h has a spectacular aura aboutalexander.h has a spectacular aura aboutalexander.h has a spectacular aura about
Exclamation Rule R18?
Hello! We were looking through the manual and we came upon a rule which is very important but we can not settle on the meaning of the rule. Could someone explain rule R18 (http://frc-manual.usfirst.org/viewItem/705#4.5.3) in the simplest, but most detailed way possible? Thanks!
2012 - Rebound Rumble - Montreal Robotics Festival - Qualified 15th - Semifinalists thanks to 3379 and 3710 (Record : 8-8-1)
2013 - Ultimate Ascent - Montreal Robotics Festival - Qualified 33rd - Dean's List Finalist : Yazid Djenadi (Record : 4-8-0)
2014 - Aerial Assist - Montreal Robotics Festival - Qualified 9th (Record : 6-4-1)
2015 - Recycle Rush *** I predicted the game ***
Unread 09-02-2014, 19:52
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: Rule R18?
You may bring to the competition up to 45 pounds worth of parts for your robot that either you, or someone whom you paid or who sponsors you, made or modified specifically for the robot. This does not include items such as motors, screws, or other Commercial Off The Shelf (COTS) parts, nor does it include raw materials, such as uncut aluminum rod or sheet stock, for example. Raw material and COTS parts you are allowed to bring as much as you like.
None of the items allowed in the 45 pounds need to be in your bag for B&T day. You may set them aside to bring to competition, or you may continue to work on them after B&T, and add them to the robot when you unbag it at competition.
R18 also specifically says that some items are excluded from the bag and don't count toward the 45 pounds; these include bumpers, batteries, and the operator console.
Unread 09-02-2014, 19:54
BobbyVanNess's Avatar
BobbyVanNess BobbyVanNess is offline
AKA: Bobby Van Ness
FRC #0020 (The Rocketeers)
BobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of light
Re: Rule R18?
This rule has been around for a while, but it's been modified in a few ways for this year. Basically, as our team understands it, you are allow to have access to 45 pounds of fabricated parts. This includes anything that has been modified for this year. It does not include COTS parts, or raw materials. However the new wording of "may have access" implies that you cant have a stock of parts to pull from (like a practice bot) outside of the venue that weighs more than 45 pounds minus whatever you bring in. Hope that helps!
2016 TVR Finalists, FLR Champions, Carver Sub-Division
2015 TVR Finalists, Carson Sub-Division Champions, IRI
2014 TVR Champions, FLR Champions, Archimedes Division, IRI
2013 WPI Regional Finalist, Connecticut Regional Champion, Archimedes Division, IRI
2013 Championship and IRI Talent Show winner
2013 - 2014 Driver: 82-43
Lead Strategy Mentor: 32-15
Unread 09-02-2014, 19:57
Re: Rule R18?
Originally Posted by mrnoble View Post
You may bring to the competition up to 45 pounds worth of parts for your robot that either you, or someone whom you paid or who sponsors you, made specifically for the robot. This does not include items such as motors, screws, or other Commercial Off The Shelf (COTS) parts, nor does it include raw materials, such as uncut aluminum rod or sheet stock, for example. Raw material and COTS parts you are allowed to bring as much as you like.
When you say that motors are not included, do you mean that they don’t count in the 45 lbs, or that we’re not allowed at all to include them?
Unread 09-02-2014, 20:00
mrnoble's Avatar
teacher/coach
Re: Rule R18?
Motors and anything else that you put on the robot AS BOUGHT through a commercial vendor (such as Ace Hardware or AndyMark) is known as COTS. Extras of these are NOT part of the 45 pounds. Bring three extra CIM motors to competition; they will not count toward the 45 pounds. Bring a box of 10-32 screws; it will not count either.
Unread 09-02-2014, 20:07
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Rule R18?
Except if it is a part of a team fabricated component (for example, if you are using the 3 CIMs on your shooter) they do count towards the weight limit.
Unread 09-02-2014, 20:10
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: Rule R18?
Half correct. If you put the CIM into a gearbox, it is considered "fabricated" as Andy Mark does not sell them pre-coupled. However, if you were to bring in the gearbox and the CIM and couple them at competition, it would be considered COTS.
Academic Student (Forever)
Unread 09-02-2014, 20:12
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
Re: Rule R18?
I'm not sure how that makes what I said half correct, I simply said that combining COTS with or without other materials makes them count towards the 45 pound limit.
Unread 09-02-2014, 20:17
Jade Z's Avatar
Jade Z Jade Z is offline
Button Masher
FRC #0180 (S.P.A.M.)
Team Role: Student
Jade Z is an unknown quantity at this point
Re: Rule R18?
When you attend a competition, you can bring tools and supplies with you so that you can work on your robot and code before and between matches.
You can bring in 45 pounds of things your team made that was not included in the bag you put your robot in on Stop Build Day. This could be anything that goes on your robot.
If you want to make your robot structure more sturdy, you might bring rivets with you to reinforce the frame. Assuming you bought these rivets from Home Depot or Lowe's, these rivets wouldn't count toward your 45 pounds because you didn't fabricate them, the manufacturer did.
If you cut out some new plates to put said rivets on, they would count towards your 45 pounds. You fabricated them, or even just modified some metal squares you found at a yard sale. The moment they are different from how your team bought them, they are "fabricated."
If you have a kid on your team who is really bright and made his very own rivet gun, yes, it would be a team-fabricated part. It doesn't count towards this 45-pound count, however, because it doesn't go on the robot, it is used for the robot.
Obviously, programs weigh nothing. If you have to bring a new CRIO because that team member's younger sibling you told to stay away from the heat gun didn't listen, it is not a fabricated part no matter how much code your team made is on it. Unless you modified it physically, but I don't know enough about how that works to advise on that particular part.
Any part you make, assemble, or modify outside of a competition is fabricated. Once you get to the competition, you can assemble your whole 120-pound robot if you have that capability so long as only 45 pounds of it you fabricated outside of the competition.
Hope that helps!
Unread 09-02-2014, 20:32
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Rule R18?
Just make sure there are no pinion gears on the CIMs.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 09-02-2014, 22:33
Re: Rule R18?
Or crimped terminals on the wires.
Unread 09-02-2014, 23:41
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Re: Rule R18?
Or make sure that even with the motors, the assembly is still under the 45 pound limit. No need to make extra work at competition if you still have weight left to use.
Unread 09-02-2014, 23:45
Gregor's Avatar
Re: Rule R18?
Or even trimmed wires...
<Since 2011
Unread 10-02-2014, 00:51
Zaque Zaque is offline
FF: Bobo Brigade
AKA: Zachary H.
FRC #3352 (Flaming Monkeys)
Zaque has a spectacular aura aboutZaque has a spectacular aura aboutZaque has a spectacular aura about
Re: Rule R18?
I have a question about this rule. Our team bought the unassembled ball shifters from VEX. If we assemble these, do they count towards our 45 pounds?
Zaque (Zach) H.
President
Programming/Electrical Lead
Unread 10-02-2014, 00:58
mrnoble's Avatar
teacher/coach
Re: Rule R18?
As I read the rules (see the glossary definition of COTS, which doesn't directly address your question but is related), the shifter is only COTS in its unassembled state. Leave it in the box.
