Go to Post ...too much to do... ...too little time... - Joe Johnson [more]
Unread 04-02-2014, 14:43
PANTHERPROJECT's Avatar
PANTHERPROJECT PANTHERPROJECT is offline
FRC #2064 (The Panther Project)
Team Role: Webmaster
PANTHERPROJECT will become famous soon enoughPANTHERPROJECT will become famous soon enough
Programming Mecanum
Hi! I'm having trouble programming the mecanum wheels. I can make the robot move sideways and rotate but I cannot make it move forward and backward and I'm not sure why. I included the important parts of my code below.
Joystick joy1 = new Joystick(1);
RobotDrive drivetrain = new RobotDrive(1, 3, 2, 4);//Front Left - 1, Rear Left - 2, Front Right - 3, Rear Right - 4
double magnitude = joy1.getMagnitude();
double direction = joy1.getDirectionDegrees();
double rotation = joy1.getZ();
drivetrain.mecanumDrive_Polar(magnitude, direction, rotation);
I know for certain that it isn't an issue with the wiring. I tried using two joysticks instead of one but that didn't work either. I've pretty much run out of ideas at this point and hope someone can help. Thank you!
Unread 04-02-2014, 14:58
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Programming Mecanum
Have you tried just using the X, Y, and Z axis instead of the Magnitude and Direction?
Unread 04-02-2014, 15:00
I have but it didn't help.
Unread 04-02-2014, 15:15
Put the bot up on blocks (wheels off the ground) and give it a pure forward command. Tell us what each of the four wheels do.
Unread 04-02-2014, 18:19
Joe Derrick's Avatar
Joe Derrick Joe Derrick is offline
Mentor - Programming
FRC #0319
Joe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of light
You could check to see if your drive motors need to be inverted. You could do this in code, or just swap red/black on one side of your robot.
Might not be the answer but another thing to try!
2010-2017 Mentor Team 319
2012 - Rockwell Automation Award Winner
2014 - Xerox Creativity in Engineering Winner, Archimedes Division
2015 - Rockwell Automation and Gracious Proffesionalism Winner, Tesla Division
2016 - North Shore and UNH District Event Winner, Carson Division
http://www.frc319.com
Unread 04-02-2014, 22:09
nyaculak nyaculak is offline
FRC #0053 (Area 53)
nyaculak will become famous soon enough
Originally Posted by PANTHERPROJECT View Post
I think you instantiated your RobotDrive instance with the motors in the wrong order. Correct me if I'm wrong, but the order should be frontLeft, rearLeft, frontRight, rearRight. Try changing the instatiation to
RobotDrive drivetrain = new RobotDrive(1, 2, 3, 4);
If that doesn't work, try as others have suggested and mount the robot up on blocks to isolate the wheels. This helps tremendously in debugging a faulty drive train.
2013 MUC DC 3rd Place, FRC DC Regional, FRC Chesapeake Regional
2012 FRC DC Regional, FRC Chesapeake Regional
ERHS Robotics Club
- FRC Team 53 "Area 53"
www.erhsroboticsclub.org
Last edited by nyaculak : 04-02-2014 at 22:10. Reason: Forgot to close code tag in the quote...like html all over again ;)
Unread 09-02-2014, 17:40
All the wheels spin inwards
Unread 09-02-2014, 17:42
That is how I instantiated it originally. When I did that, the wheels moved forward, backward and rotated but did not move side to side.
Unread 09-02-2014, 18:30
That's why it won't go forward of course.
What do the wheels do when you give a pure reverse command?
A pure strafe right command?
etc
Unread 09-02-2014, 21:28
etc
When given the pure reverse command, I believe they all spin outward but the wheels work fine while shifting to the right, left and rotating so if I were to invert the motors it wouldn't help much.
Unread 10-02-2014, 07:47
Flywheel Police
I'm pretty sure nyaculak is correct that you have the motors going into the RobotDrive object incorrectly. It should be frontLeft, rearLeft, frontRight, rearRight.
RobotDrive(int frontLeftMotor, int rearLeftMotor, int frontRightMotor, int rearRightMotor)
          Constructor for RobotDrive with 4 motors specified with channel numbers.
Unread 10-02-2014, 21:35
AKA: Brad
#0190 ( Gompei and the Herd)
Code for doing Mecanum with joysticks looks like this:
myRobotDrive.mecanumDrive_Cartesian(joy1.getX(), joy1.getY(), joy1.getTwist());
Optionally you can put the angle from a gyro in as the optional 4th parameter.
One possible problem is that some of the motors may need to be inverted depending on how they are configured. To determine that, put the robot on blocks and drive it with the joysticks and see what it is doing. You can call the
setInvertedMotor()
method on the side that is going in the wrong direction.
Brad Miller
Robotics Resource Center
