Go to Post Thank you for participating. It'd be a blank website without all of you. :) - Brandon Martus [more]
Unread 10-02-2014, 08:27
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Rule R18?
Per Q&A Q257: Yes, a MECHANISM which has been assembled from a kit from a vendor is considered a FABRICATED ITEM.
Unread 10-02-2014, 08:40
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Re: Rule R18?
Originally Posted by Jade Z View Post
If you cut out some new plates to put said rivets on, they would count towards your 45 pounds. You fabricated them, or even just modified some metal squares you found at a yard sale. The moment they are different from how your team bought them, they are "fabricated."
Ummm ... Is that actually correct? I thought it was the moment they are different from what you can buy off the shelf.
For instance, we may get 1/8" aluminum plate from our vendor in 4'x8' sheets (we don't, but we could). If we cut that down to 2'x2' (also available) without putting any holes, bends, or other modifications, wouldn't it still be COTS, just a different part number? For that matter, couldn't it count as raw material?
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
