Broken AM super shifter
Sorry should say BROKEN
Just a heads up for you all. We were running our practice bot Friday with some super shifters that had about 2 seasons on them when we lost all push on one side of the bot. It was stuck in neutral. The pneumatic shift cylinder what going in and out but it did not change gears. So, obviously the dog gear was stuck in the middle and the shift rod was no longer "attached" to it. Had to be that LITTLE screw that connects the dog gear to the shift rod. After about a half hour of work we managed to pull the box off the bot and got it apart and sure enough the little screw was not where it was supposed to be. Found it stuck in the grease. Luckily not in a gear. Tried to screw it back in when we realized it was not long enough. Pulled the dog gear and sure enough there was a piece still stuck in the dog gear and another little piece in some grease under one of the gears. Now, off to Ace to find a new screw. NOT It is a 2.4MM screw that nobody had. So, we improvised. DIdn't have time to wait for AM to send one(I don't even know if they sell them). Only thing we could find close was a 4-40. A little big but only slightly. Drilled out the dog gear and the shift rod then retapped the other side of the dog gear and we were back in action. Have any of you had this issue while pneumatically shifting these transmisions? Seems like a mighty small screw to take all that force. Do you run a lower pressure to the shifting cylinders? Thanks |
Re: Briken AM super shifter
Have you contacted AndyMark to let them know about the failure yet? They might be able to improve future versions of this product so this does not happen again. That being said, I think a small screw lasting 2 seasons like that is pretty impressive.
You could always try something new like the Linear Servo, although it appears that is optimized for the Sonic Shifter. I do admit that it sucks when something like that fails this late in the build season, at least it wasn't in the middle of a match! |
Re: Broken AM super shifter
Do the new ones come with screws or roll pins? I seem to remember roll pins in ours.
New ones come with a 4-40 screw.
We had one of ours (couple of years old) with the small metric screw break in 2012 just before ship day. Pulled out the spare shifter parts and discovered they had the new 4-40's in them. We re-tapped and drilled the old ones to 4-40's, they are now our spares, I've heard of no problems with the 4-40's at all. |
Thanks I will both contact AM and install a regulator.
#7
Bruce,
Thanks for calling us at AndyMark earlier. To confirm what previous posts stated, we currently use a 4-40 screw in the dog gear. The current dog assembly can be found here: http://www.andymark.com/product-p/am-0020.htm Liz |
#8
We broke one of the new 4-40 screws in a new sonic shifter on our practice bot. The bot went a few weeks of basic testing and a week 0 scrimmage on Saturday prior to breaking. We were running 60 psi on our shifting cylinders. it looks like we may want to lower the pressure to reduce wear. Have teams been successful shifting at lower pressures?
