Go to Post I just like that PVC is the most basic need of humankind according to that diagram. Whatever would we do without it?! - Po-ser [more]
Unread 10-02-2014, 12:13
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
Mounting solenoids
We have several Festo double solenoids. They each have 2 little holes in them that look like they're trying to be for mounting. Are tiny little machine screws the way to go or would it be OK to just use Velcro?
Any other thoughts on how to mount them?
Unread 10-02-2014, 12:29
shewejff shewejff is offline
Jeffrey S
AKA: Jeffrey S
FRC #1025 (Impi Robotics)
shewejff is on a distinguished road
Re: Mounting solenoids
The holes fit #4 screws, which aren't too uncommon.
Actually drilling corresponding holes in the thing you're mounting to and using a couple zip ties should do just fine. We've never had any issues zip tying solenoids to the robot before.
The screws do look a little nicer
Unread 10-02-2014, 13:02
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
We stacked 5 together. Had to get some threaded rod (4-40) from the local hardware store. You may find it easier with connections if you put a small spacer/washer between the solenoids.
2014 Wisconsin Engineering Inspiration Award, CIR Engineering Excellence Award
2013 Croosroads Engineering Inspiration Award
2012 BMR Judge's Award, 2011 BMR Regional Champions, BMR Motorola Quality Award, BMR Autodesk Excellence in Design Award, 2010 BMR Regional finalists; 2009 BMR General Motors Industrial Design Award; 2008 BMR Engineering Inspiration Award; 2007 BMR Rookie All-Star Award
Darrin Munter - N9SDD
Advanced Technology Services
