Go to Post The extra button could also just be a spare, but that's far less interesting than other possibilities, so let's keep speculating. - Caleb Sykes [more]
Unread 10-02-2014, 12:22
Re: Compressor will not start!
You are not initializing the objects in the same order they are declared.
Just to verify, if you remove the DB-37 cable from the Digital Sidecar, are all 3 power LEDs on the Digital Sidecar brightly lit?
Originally Posted by DangitDrBob View Post
We just tried it and it didn't change anything. Yes, the motors and Digital I/O both work. We can drive it around still, but the compressor will not start. We have also check with last year's code which worked, but it didn't work on this robot.
What does this mean? Can you describe in more detail what you did and what did and didn't work?
Unread 10-02-2014, 14:14
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
We have tested the Spike relay and its fuse and both are working properly. !
After you do get the software side ironed out, you may want to replace your fuse with a 20A breaker when the fuse blows after the first couple times your compresser kicks on.
R64
E. If powering the compressor, the fuse on a Spike H-Bridge Relay may be replaced with a 20A Snap-Action circuit breaker.
Unread 10-02-2014, 14:56
Jasmine Zhou Jasmine Zhou is offline
FRC #1678
Jasmine Zhou has much to be proud ofJasmine Zhou has much to be proud ofJasmine Zhou has much to be proud ofJasmine Zhou has much to be proud ofJasmine Zhou has much to be proud ofJasmine Zhou has much to be proud ofJasmine Zhou has much to be proud ofJasmine Zhou has much to be proud of
For relay testing, try running it as Ac.Set(Relay::kForward); instead of Relay::kOn. That should run the compressor and turn the light on the spike green. Forward and reverse aren't the same as on; someone who knows more can explain that. If that works, then the spike and its connections are good.
Also make sure your pressure switch is working and wired properly: if it's not sending signal to the digital sidecar, the compressor won't (shouldn't) run.
Unread 10-02-2014, 16:24
Andy A. Andy A. is offline
Getting old
FRC #0095
The simple answer is that 'on' means both output terminals of the spike are at +12 volts, as opposed to 'forward' or 'reverse' where one is + and the other -.
The utility being that 'on' allows you to power two loads connected to a shared ground. It's not a common thing in FRC, to the point I wasn't really aware of the functionality till it showed up as a 'bug' in this years code. The obvious use would be running two solenoids with one spike. In that case, 'forward' or 'reverse' would power one load but not the other, and 'on' would power both.
Unread 15-02-2014, 22:01
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
We had an issue getting our compressor to work also. Turns out the pressure switch was broken. You can test this by simply shorting the 2 terminals on the switch to close the circuit and seeing it that fixes the issue. If it does, try replacing the pressure switch.
Unread 16-02-2014, 22:45
DangitDrBob DangitDrBob is offline
FRC #4135
DangitDrBob is an unknown quantity at this point
Thanks for all the suggestions. We called the support and they helped us fix things.
