Go to Post It is NOT possible to fail within FIRST. It IS possible to fail within the competition (whatever your criteria for failure may be). - JVN [more]
Unread 07-02-2014, 19:25
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Is this solenoid legal?
Is this solenoid legal to use in competition in the 2013-14 season?
VALVE, 1/8 NPT, Cv=0.78, 24VDC, DOUBLE SOLENOID, 5-PORT, 2-POSITION
Link: http://www.automationdirect.com/adc/...)/AVS-5221-24D
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 07-02-2014, 19:43
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Is this solenoid legal?
R77 clearly says what pneumatic components are and aren't allowed. R77-C specifically applies to solenoid valves.
Unread 07-02-2014, 19:46
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
It meets all of the requirements in rule R77-C, so yes, it is legal.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Yes it is legal. The nominal working pressure is 115psi so absent any other documentation you will need a secondary relief valve on the low pressure circuit per rule
Unread 10-02-2014, 13:25
RandeJ RandeJ is offline
AKA: Rande Johnson
FRC #4931 (Edwardsville Tech)
RandeJ is an unknown quantity at this point
Just got a response from vendor regarding max pressure. Do you think a copy of this email is good enough to pass inspection (probably) without a secondary pressure relief valve?
Here is the technical support response to your inquiry:
Rande,
The proof pressure for this valve is 215 psig. Anything up to this value
will not cause damage to the unit. We had to obtain this figure from the
vendor directly, so sorry we don't have any documentation.
Please advise if you need any additional information. Thank you.
Frank DeMarco
Technical Support Team
AutomationDirect.com
If you have other questions, or require additional information, please call
or reply to this email (be sure the call # appears in the subject line).
The most practical automation products, at the lowest prices, shipped the
same day.
Unread 10-02-2014, 13:41
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
No. See Q241 in the Q&A - "Working Pressure is not Proof Pressure."
EDIT: While I've been frustrated over the years with the alternative reality English dictionaries that only the GDC has access to, I agree with their position on this. Proof pressure is usually a multiplier applied to working pressure, but there doesn't appear to be consensus on what that multiplier is.
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
Unread 10-02-2014, 13:48
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
So in terms of safety. It is completely & totally safe. In terms of the rules, you need a secondary relief valve. A wise robot builder complies with both.
Unread 10-02-2014, 16:24
AKA: Rande Johnson
Oh joy, but we'll put two into be safe. Thanks for all the clarifications.
Unread 10-02-2014, 16:42
AKA: Karlis Musa
Oh joy, but we'll put two in, to be safe. Thanks for all the clarifications.
Sorry to belabor this, but it's not a matter of being "safe" (in the context of satisfying the rules and/or the Inspector). The max working pressure of those solenoids is 115 PSI, which requires the second relief valve. (We also have the same issue. We mounted the additional relief valve in one of the ancillary ports on our primary regulator.)
-Karlis
