Go to Post At this time of the season, there is only one response: BAAAAAAAAA-humbug! - dlavery [more]
Unread 10-02-2014, 13:36
ThunderPorpoise's Avatar
ThunderPorpoise ThunderPorpoise is offline
AKA: Benjamin Hollinger
FRC #4373 (RooBotics)
ThunderPorpoise is an unknown quantity at this point
Regarding extensions
It has been a rule in past years that at the beginning of a match all robots must begin UN-extended. I've taken a quick look through the rules this year but I haven't seen anything similar. Am I just missing something or has this rule been removed?
Unread 10-02-2014, 13:40
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Regarding extensions
R4 is the rule you're looking for. STARTING CONFIGURATION requires all appendages to be inside the frame perimeter.
Unread 10-02-2014, 13:41
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
R4 says that STARTING CONFIGURATION means no part of a robot extends outside the frame perimeter.
Unread 10-02-2014, 13:42
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
G4 dictates the robot must start wtihin it's STARTING CONFIGURATION.
G4
When placed on the FIELD, each ROBOT must be:
A.in compliance with all ROBOT rules (i.e. have passed Inspection),
B.confined to its STARTING CONFIGURATION,
C.positioned such that the only contact between the ROBOT and the carpet is in their GOALIE ZONE,
or
positioned such that the only contact between the ROBOT and the carpet is in the white ZONE with the ROBOT between the TRUSS and their GOALS, and
D.fully supported by the floor.
TEAMS positioning ROBOTS in the white ZONE have precedence over opponents placing ROBOTS in the GOALIE ZONE.
Violation: If fix is a quick remedy: the MATCH won’t start until all requirements are met. If it is not a quick remedy: the ROBOT will be DISABLED and must be re-Inspected.
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Manual:
B. confined to its STARTING CONFIGURATION,
Originally Posted by Glossary
STARTING CONFIGURATION: The physical configuration and orientation of the ROBOT when the MATCH is started.
In the STARTING CONFIGURATION, no part of the ROBOT may extend outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc.
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Rule 3.2.2 - G4
or
Definition of STARTING CONFIGURATION:
STARTING CONFIGURATION: The physical configuration and orientation of the ROBOT when the MATCH is started. This is the state of the ROBOT immediately before being Enabled by the Field Management System, before the ROBOT takes any actions, deploys any MECHANISMS, or moves away from the starting location. This configuration is static, and does not change during a single MATCH (although it may change from MATCH to MATCH). In the STARTING CONFIGURATION, no part of the ROBOT may extend outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc.
If a ROBOT is designed as intended and pushed up against a vertical wall (in STARTING CONFIGURATION and with BUMPERS removed), only the FRAME PERIMETER (or minor protrusions) will be in contact with the wall.
Unread 10-02-2014, 13:47
Well there we go.
Whoops!
Thank you.
