Go to Post I hope you realize that by starting this thread you have earned yourself a permanent place at the "WOEWITWISTFT" ("What On Earth Was I Thinking When I Started THAT FIRST Trend?") table. It's members are few, but the conversation is the most honest and amusing in the entire place. ;) - Jessica Boucher [more]
Unread 10-02-2014, 13:54
Irene-4574 Irene-4574 is offline
FRC #4763
Irene-4574 is an unknown quantity at this point
Issues with adding more than 4 Motor Controllers
Hello!
Our team is having trouble connecting multiple motor controllers to our robot.
Our drive system works fine, with 4 Talons, but if we try to add even one more in, the code crashes when we enable the robot, causing the drive system to run for a second or so and then break, rendering it inoperable, until we disable and re-enable.
We've tried changing the fifth to a jaguar, and a victor (as well as the original talon), but nothing works. (removing the fifth from the code causes it to run fine)
The issue doesn't seem to be in our code, since the separately created labview and c++ code both have this issue.
Does anyone know what might be causing this? Any help would be extremely appreciated!!
Unread 10-02-2014, 14:00
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Issues with adding more than 4 Motor Controllers
By process of elimination, have you tried replacing your digital sidecar? It seems that it isn't the motor controller and it isn't the code, so try the next item, PWM cable, Digital Sidecar, DB37 Cable, etc.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 10-02-2014, 14:06
What do you see that leads you to the conclusion that the code is crashing?
This type of problem is commonly caused by not properly powering the digital sidecar. If you remove the DB-37 cable from the Digital Sidecar, are all 3 power LEDs brightly lit?
Unread 10-02-2014, 16:25
FRC #4763
We tried unplugging the DB37 and all 3 lights did not light up.
We're running power to the sidecar from the 5 volt output on the power distribution board.
We've had issues with sidecars in the past. However, the sidecar we are using should work.
Should we remove the power from the 5 volt and replace it with the 12 volt?
Thank you for the speedy replies and your help!
Unread 10-02-2014, 16:28
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
You should definitely do that. The Digital Sidecar needs 12 volts to work properly. The 5 volt output on the Power Distribution Board should be reserved for the camera if you are using one.
I'm right 90% of the time, so why worry about the other 3%?
Unread 10-02-2014, 17:50
Originally Posted by Irene-4574 View Post
We're running power to the sidecar from the 5 volt output on the power distribution board... Should we remove the power from the 5 volt and replace it with the 12 volt?!
Yes. And you should also seriously consider downloading the wiring instructions from the usfirst.org and screenstepslive.com websites and have someone carefully check all your wiring. It may save you a lot of unnecessary grief and downtime.
Unread 10-02-2014, 18:59
FRC #4763
We did as you suggested, and it worked perfectly.
Thank you for the help, we'll be sure to check these things in the future.
