Re: Compressor will not start!
For relay testing, try running it as Ac.Set(Relay::kForward); instead of Relay::kOn. That should run the compressor and turn the light on the spike green. Forward and reverse aren't the same as on; someone who knows more can explain that. If that works, then the spike and its connections are good.
Also make sure your pressure switch is working and wired properly: if it's not sending signal to the digital sidecar, the compressor won't (shouldn't) run. |
The utility being that 'on' allows you to power two loads connected to a shared ground. It's not a common thing in FRC, to the point I wasn't really aware of the functionality till it showed up as a 'bug' in this years code. The obvious use would be running two solenoids with one spike. In that case, 'forward' or 'reverse' would power one load but not the other, and 'on' would power both. |
We had an issue getting our compressor to work also. Turns out the pressure switch was broken. You can test this by simply shorting the 2 terminals on the switch to close the circuit and seeing it that fixes the issue. If it does, try replacing the pressure switch.
Thanks for all the suggestions. We called the support and they helped us fix things.
