Go to Post We are just here to give back to a program that gave us so much as students. - Alex Cormier [more]
Unread 10-02-2014, 16:11
Live 4 Now283 Live 4 Now283 is offline
Gamertag Xbox- Live 4 Now28 Add mee
AKA: Jae Horvath
FRC #1831 (Gilford Screaming Eagles)
Team Role: Student
Live 4 Now283 is an unknown quantity at this point
Cool Milling Machine Question
A simple and quick question. How much tork does it take to stall a milling machine?
Unread 10-02-2014, 16:13
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: Milling Machine Question
The torque limits vary machine to machine, but it's usually quite a lot (i.e. significantly more than it should experience under proper working conditions).
Unread 10-02-2014, 16:27
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Specs for a Fadal VMC 4020
SPINDLE DRIVE MOTOR AC, VECTOR Drive
HORSEPOWER* 15 HP / 22.5 HPA , 30 HPB
TORQUE* 160 ft.-lbs. / 220 ft.-lbs.A / 270 ft.-lbs.B
AXIS DRIVE MOTOR (X/Y/Z) AC, 3,800 lbs.* thrust
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 10-02-2014, 16:40
smclean1969 smclean1969 is offline
FRC #3512
smclean1969 is an unknown quantity at this point
It varies quite a bit from one machine to another. If you have your mill stalling out, there could be a few different issues. The most likely one is you're taking too big of a cut based on what the machine is rated for. The easy solution is to take a smaller cut.
You could also using cutting oil or some other type of approved lubricant to maintain the material at a cooler temperature which prevents chips from being welded to the part it was just cut from. It will also extend the life of your end mills.
Your end mills may be dull. If they're used heavily, then you probably should be replacing them every other year.
A little more complicated may be if the belts inside the mill are worn out so they don't have as much friction to turn the spindle.
Scott McLean
FIRST Team 3512, the Spartatroniks
Team role: mentor
2011: Highest Rookie Seed and Rookie Inspiration Award Long Beach Competition
2012: Winner Los Angeles Regional -- w/ Team 987 and Team 1717
2013: Finalist Los Angeles Regional -- w/ Team 599 and Team 981; Engineering Excellence
2015: Entrepreneurship Award - Ventura Regional
Unread 10-02-2014, 17:15
Master Mac Master Mac is offline
FRC #1075
Master Mac is an unknown quantity at this point
My experience your removing to much material with each pass, causing it to stall, or the bit is not sharp, or plugged up, what type of material are you milling?
Unread 10-02-2014, 17:27
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
I guess the question in reply is: Why? Are you stalling out a mill? If so, what make, model, and motor size is involved, as well as the specifics of the cut? There is noting that I can think of that a FRC team should be doing that could stall out a standard vertical mill (mini-mills etc are a different story).
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 11-02-2014, 08:18
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Excess chip loading:
1) number of teeth engaged with the cut to large.
2) volume of metal per chip too large (excess depth per pass & feed per tooth)
3) strength of metal per # of simultaneous flutes cutting to great.
4) diameter of cutter too large for spindle motor torque
5) cutter teeth too dull or damaged
6) profile of cutter giving too much linear contact with teeth
Other:
7) if a variable speed spindle motor, running at too low of an RPM
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 11-02-2014, 08:28
Mr. Mike's Avatar
Mr. Mike Mr. Mike is offline
FRC #3138 (Innovators)
Mr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to all
Other:
8) If you are running a manual mill on a static phase converter it loses 1/3 of the hourse power.
