Re: Issues with adding more than 4 Motor Controllers
We tried unplugging the DB37 and all 3 lights did not light up.
We're running power to the sidecar from the 5 volt output on the power distribution board. We've had issues with sidecars in the past. However, the sidecar we are using should work. Should we remove the power from the 5 volt and replace it with the 12 volt? Thank you for the speedy replies and your help! |
