Go to Post I hope you realize that by starting this thread you have earned yourself a permanent place at the "WOEWITWISTFT" ("What On Earth Was I Thinking When I Started THAT FIRST Trend?") table. It's members are few, but the conversation is the most honest and amusing in the entire place. ;) - Jessica Boucher [more]
Unread 10-02-2014, 17:31
Wzup4021 Wzup4021 is offline
FRC #4021 (igKnightion)
Wzup4021 is an unknown quantity at this point
CIM motors vibrate/jitter
We have a mock up chassis for testing code on. It has the bare essentials, including 2 talons and 2 mini-CIMs. When we power up the setup and run code, everything works fine, however the 2 CIMs vibrate/jitter. We have tried different CIMs, different sizes, different Talons, they still jitter. We've tried everything we can think of an they still jitter. Any help would be great, thanks.
Unread 10-02-2014, 17:33
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: CIM motors vibrate/jitter
So the robot "twitches" on the ground, as in it drives very slightly back and forth without user input telling it to do that?
Is the robot enabled when this happens (so does it happen when the robot is disabled as well)?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 10-02-2014, 17:36
We don't have any wheels hooked up to it, as it is just on a C-channel frame. When we enable it, the lights on the Talons flicker between red and orange. When it is disabled, they don't jitter.
Unread 10-02-2014, 17:39
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
It's (most likely) a code issue. Red means the Talon is getting a reverse signal, while orange means the Talon is getting a neutral signal. If it's bouncing between the two, it's most likely caused by a code issue, but you can try calibrating the Talons as well.
Unread 10-02-2014, 17:41
Although possible, I don't believe so. We've sent it code that had no other commands other then to set the motors to 0. It still bounces back and forth several times a second between the two colors.
Unread 10-02-2014, 17:44
dellagd's Avatar
AKA: Griffin D
Are you routing your PWM wires parallel with all of your power wires to the motors? The induced current could mess with the signal, but if you're not running them I doubt this would occur. Just controls food for thought.
That being said, do calibrate them. If the calibration is such that a zero signal is right on the line in the talon of neutral/reverse, it would probably bounce between them as you said.
Unread 10-02-2014, 17:45
Well, we have the PWM wires tied next to eachother most of the way until they split, and one place that could be a problem is I looped them up at one point to shorten them up, just a simple back and around loop, but could that be the issue?
Unread 10-02-2014, 17:46
It is very possible that something is telling the Talons to go full throttle and in doing so they trip the breaker feeding each one. Do you have any wiring attached to the output of the Talons? Double check this to be sure you don't have a short there.
Unread 10-02-2014, 17:47
cgmv123's Avatar
AKA: Max Vrany
Something is causing the mixed signal and thus the jitter. Check your DSC connections.
Unread 10-02-2014, 17:48
Yes, we have wiring. They are not making contact though, it's circle screw on connectors connected to wire running straight to the CIMs, no metal contact.
Unread 10-02-2014, 17:49
dellagd's Avatar
AKA: Griffin D
Having the PWMs next to each other wouldn't be an issue, just big current flow through the power wires from the PDB.
http://www.crosstheroadelectronics.c...Manual_1_1.pdf - Pg 7 is the calibration instructions.
Unread 10-02-2014, 17:56
All of the DSC connections are proper. We disconnected them all and reconnected them.
Unread 10-02-2014, 18:08
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Are these Talon SRs? If so, then red/orange flashing is the fault code for under voltage (<3.3V), over temperature (>170C), or shorted output transistor.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 11-02-2014, 17:48
Yes, I believe they are the Talon SR motor controllers. This doesn't seem like an error code, as it is flashing extremely fast, as in 15+ times per second, and the motors are actually moving. They are hooked up identical to our robot, so they shouldn't be under volted. They have fans on top of them, and the flashing is all they do, so it can't be over heating. I also doubt that it is a shorted out transistor, seeing as we have tried different talons. It must be something to do with the DSC or CRio, however we have no clue what. We've reconnected everything, but nothing seems to work.
Unread 11-02-2014, 18:02
Have you tried calibrating them as suggested by dellagd above? It sounds like they are getting a signal right on the edge of neutral and based on timing jitter it is alternating between neutral and a very low speed reverse.
