Go to Post "Its not a glitch its a new feature, we just dont know how to use it yet" - Cuog [more]
Unread 10-02-2014, 18:59
nrogals nrogals is offline
None #3173
nrogals is on a distinguished road
Supporting 40lbs Arm with Motor?
Hello Everyone,
Our team is looking to put a long rage shooter and acquisition unit on a single arm. Both units will weigh about 20lbs. The torque on the motor will be near 70-80 foot pounds.
Can a Mini CIM and a multiple stage gear box hold the arm up via friction in the gear box. If not, is there a method for running the motor with a certain voltage pattern such that it holds the arm and will not pull a sufficient amount of power away from the drive train.(Electric Break)
If not, at last resort, does anyone have any suggestions to apply a mechanical break to the motor shaft.
Thanks!!!!!
