Go to Post Some clever fellow a few years back made a little scooter based on this principal and made so much on the idea he can afford the finest denim in the land. - phrontist [more]
Unread 15-02-2003, 23:38
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
Stripping Threads on Gear Box
I would like to ask has any team had the aluminum piece that screws into the drill motor strip its threads. The reason I am asking is that we have gone thru the ones that FIRST shipped and now we have stripped one of the ones that our machine shop made for use to replace the bad one. We have used Locktight in the piece but it seems that as we drive the robot that when we put the motor into reverse that we are back drilling and it trys to unscrew itself. Could we be putting the piece on. Our next step is to JB weld the piece to the drill motor and make it so it cannot come off without breaking the drill motor. Please comment because we are frustrated as we are so close to having a nice driving robot.
Unread 16-02-2003, 08:36
Matthew_H's Avatar
Ubergeek
#1028 (Ubergeeks)
Help
I am assuming that nobody has had this problem. How many people are using the drive mounts that are in the kit of parts and are they working correctly.
Unread 16-02-2003, 09:37
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
why not put 2 pins through the coupler and the motor output shaft, put one pin and then another 90 degrees from that one
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 16-02-2003, 11:07
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
There are two reverse threaded allen screws that screw into the inside of the aluminum piece to keep it from un-screwing.
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 16-02-2003, 21:57
Thes screws came with the original kit and you may not have noticed them. They are left hand thread used in the drill to keep the chuck on. They are essential unless the motor is only run in one direction, that which would cause it to tighten.
Unread 16-02-2003, 22:00
Matthew_H's Avatar
Ubergeek
#1028 (Ubergeeks)
Thanks
I will look for these screws in the morning. This will save use from having to use JB weld.
Do these screws go into the hole on the aluminum piece. Is there a pdf on where it goes?
Thanks Again.
Unread 16-02-2003, 22:49
Owen Owen is offline
#1359 (Scalawags)
Owen is an unknown quantity at this point
Our came out also even with the screws. So we drilled it and used roll pins.
Unread 17-02-2003, 07:22
Re: Thanks
Thanks Again.
There is no documentation that I am aware of. Once you have all the parts in your hand, it should be clearer. (I think all of us are assuming you are using the FIRST drive system.)
Unread 17-02-2003, 08:46
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Easy hear is what you do put the coupler on the drill motor then there is a little hole in the middle of the coupler put the screw there and tighten it.
That is odd our drill motors did not come apart with the screws.
Unread 17-02-2003, 09:38
Matt H,
Here is a blueprint for the screw...
http://www2.usfirst.org/2003comp/Specs/SB_lh_screw.pdf
if that helps.
Unread 17-02-2003, 14:18
Matthew_H's Avatar
Ubergeek
#1028 (Ubergeeks)
It works
I was able to quickly find the screws and install them this morning. Everything seems to be holding very well. Thanks for everyones help.
Unread 17-02-2003, 22:05
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
for some reason our screws kept falling out, and we fixed it with a very thin washer.... not sure why that worked, but when we did it, it seemed perfectly reasonable, so there must have been some actual inteligence used...
Trust, Love, and Magic
Unread 17-02-2003, 22:17
f22flyboy's Avatar
we fixed it with an allen wrench and alot of torque
Team 540 Forums
Image Discuss: Team 60 - New Gear Box CD47-Bot Robot Showcase 2 09-02-2003 20:29
reducing gear box weight mickjagger Technical Discussion 16 23-01-2003 20:35
Please help! Grease in the drill motor gear box? archiver 2000 2 23-06-2002 23:07
Grease inside the Drill Motor gear box? archiver 2000 2 23-06-2002 23:07
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
