Go to Post There is no such thing as "un-GP." - Tetraman [more]
Unread 10-02-2014, 22:35
O-H
FRC #0048 (Delphi E.L.I.T.E.)
pic: Team 48 - Lock n' Load
Unread 10-02-2014, 22:36
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Re: pic: Team 48 - Lock n' Load
That's impressive. What are you doing in terms of spring force? What's the weight of the ram? What's the starting gap between the ram and the ball (if any)?
Unread 10-02-2014, 23:16
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
It reminds me of a MK19 grenade launcher...
Unread 10-02-2014, 23:36
O-H
Currently, there are two www.centuryspring.com #81153 springs on there, providing about 50 lb. of force each in the low power setting, and 80 lb. of force each in the high power setting.
The high power shot is selected by extending the 2 3" stroke cylinders, which adds 3" of pre-load onto the springs.
The motor/gearbox pulls the springs back to firing position (roughly 6" of pullback). When the launcher fires, the majority of the stroke takes place with the ball in contact with the ram.
The ram is 1" round igus aluminum rod with a McMaster 3/8" wide, 20 DP, 14.5 PA rack gear affixed. The rod slides through two open-top igus linear bearing pillow blocks. I actually don't know how much the ram weighs. The overall claw/launcher combo projects to weigh around 35 lbs.
I was kinda thinking a .30 or .50 cal machine gun, but I think I like yours better. :-)
Unread 11-02-2014, 00:27
Procolsaurus's Avatar
Procolsaurus Procolsaurus is offline
AKA: Robert Pond
FRC #4118 (Roaring Riptide)
Procolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really nice
Holy Perspective! It looks like its 4 feet tall
mschwab013's Avatar
mschwab013 mschwab013 is offline
AKA: Matt Schwabenbauer
FRC #0291
mschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to all
That is terrifyingly awesome. Great job as always!
2013 Pittsburgh- Gracious Professionalism award, 7th seed, 6th alliance captian, quarter-finalist(291,3492,4601)
2013 Queen CIty- Chairman's Award, 39th seed
2012 Pittsburgh- 23rd seed
2012 Buckeye- 34th seed, 2nd alliance, quarter-finalist(291,1241,4085)
2011 Pittsburgh- 13th seed, 5th alliance, quarter-finalist(291,337,3504)
2011 Buckeye- 18th seed, 8th alliance, quarter-finalist(279,291,3496)
2010 Finger Lakes- 15th seed, 5th alliance, quarter-finalist(291,1507,1559)
2010 Buckeye- Chairman's Award, Imagery Award, Quality Award, 4th seed, 1st pick, 1st alliance, semi-finalist(291,1014,1629)
Unread 11-02-2014, 00:37
O-H
The main structural element is 4" x 4" x 1/8" wall aluminum, if that helps.
Unread 11-02-2014, 00:52
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Fixed
Unread 11-02-2014, 00:59
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Our linear launcher (not actually a puncher, but similar) uses aluminum extrusion with those same dimensions as its main structure, and our winch gear system is integrated, so our aluminum box structure serves both as a gearbox and launcher track all in one piece. Since our launcher stores a ridiculous amount of energy, we now understand that these types of ball shooting mechanisms may just need that much structure!
Unread 11-02-2014, 01:56
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Wow, that's surprisingly little force for such a great launch. We're hitting 220 pounds at full pullback in our shooter, and we're still not getting much distance as we want.
Any reason for the tiny little pusher plate? Or are you going to replace this with something else?
-Plutarch
Unread 11-02-2014, 03:15
O-H
We're pretty happy with the efficiency. I cannot imagine it is the only reason, but our rack and pinion cocking system completely disengages the cocking pinion from the rack on the plunger rod - the pinion has missing teeth by design - so there is no drag on the plunger rod from a winch when it fires forward.
The igus linear bearings and aluminum shaft are also (literally) quite slick.
Honestly, the shape/size was kinda arbitrary - we just wanted something larger than the diameter of the 1" plunger rod to start. The end of the rod is threaded so we can put in larger-diameter endcaps if we want and examine the effect on distance (and more likely, shot consistency).
Unread 11-02-2014, 12:08
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Hi Travis
How far are you hitting the ball?
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 11-02-2014, 12:19
This looks like a really long shot but I'm assuming that the camera perspective affects it a bit. What is the maximum effective range of this launcher?
Unread 11-02-2014, 21:51
O-H
Originally Posted by Wayne Doenges View Post
Hi Travis
Our low power shot was hitting from about 16' tonight.
Unread 11-02-2014, 22:36
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Is that shots from 16' into the goal, 16' to hit the ground, or something else?
-Plutarch
