Go to Post Oh, please, please, GDC! Give us a corn game! - Richard Wallace [more]
Unread 15-02-2003, 18:54
Team168 Team168 is offline
#0168 (Flashbacks)
Team168 is an unknown quantity at this point
Question Globe Motor
We have a globe motor set to a speed controller on the RC and we have two digital switches on the OI to control it. What do we set the PWM to in the Serout command?
Adapt, Adjust, Overcome
Unread 15-02-2003, 20:09
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Here's my suggestion:
globe_motor VAR byte              ' put this in the "declare variables" section
' Main Loop:
globe_motor = 127 + (127*switch_one) - (127*switch_two)
You gotta put the globe_motor in your serout, in whatever PWM output you want.
With this code, the motor will turn CW if switch_one is pressed, and CCW if switch_two is on. If both are pressed, nothing happens.
Hope I helped, feel free to ask any question.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 16-02-2003, 00:05
Goya Goya is offline
#0019 (Big Red)
Goya is an unknown quantity at this point
Send a message via AIM to Goya
Just a quick question -
Is PBASIC operand supportive? For example, would it work mathematically left to right, do exponents before subtraction, etc?
Unread 16-02-2003, 11:50
Manoel's Avatar
It works from left to right, period.
For example:
3+2*6
In normal math, you would multiply 2 by 6 and then add 3, for a total of 15. In PBasic, you sum 2 to 3 and then multiply by 6, resulting in 30. You have to use parentheses if you want to give any operation priority over another.
Hope I was clear.
Brazilian Machine
Team # 383
Globe Motor archiver 2000 4 24-06-2002 00:15
Globe Motor archiver 2000 0 24-06-2002 00:15
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
Globe Motor and Thermal Protection archiver 1999 0 23-06-2002 22:03
Help! Need a Globe Motor Dodd Motors 0 24-07-2001 11:57
