Go to Post So once and a while no matter how addicted you may be, try to think outside the 48'x24' box of FIRST. - Tytus Gerrish [more]
Unread 09-02-2014, 00:53
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Maxbotix analog programming
Does anyone have any example code of getting the distance to something and driving that distance with a macho tis range finder?
Unread 11-02-2014, 02:26
irvingc irvingc is offline
FRC #0948 (Newport Robotics Group)
irvingc is on a distinguished road
Re: Maxbotix analog programming
What you're asking is actually not so simple! Just getting the distance reading from the sensor can be somewhat complicated, depending on the interface. Here's some code I dug up from the last time we used an ultrasonic sensor that connected to the I2C bus (this was before we switched to the command-based framework):
import edu.wpi.first.wpilibj.*;
import java.util.TimerTask;
public class NRGUltrasonic
    public static final boolean USING_ULTRASONIC = false;
    private Timer timer;
    private java.util.Timer controlLoop;
    private DigitalModule digMod;
    private I2C i2c;
    private static final int ULTRASONIC_SLOT = 4;
    private static final int ULTRASONIC_ADDRESS = 0xE0;
    private static final int ECHO_ADDRESS_HIGH = 2;
    private static final int ECHO_ADDRESS_LOW = 3;
    private int dist;
    private double period;
    private boolean writeFail;
    private class UltrasonicTask extends TimerTask
	private NRGUltrasonic u;
	public UltrasonicTask(NRGUltrasonic ultrasonic)
	    if (ultrasonic == null)
		throw new NullPointerException("Given Ultrasonic was null");
	    this.u = ultrasonic;
	public void run()
	    u.setDist();
    public NRGUltrasonic()
	dist = 0;
	writeFail = false;
	if(USING_ULTRASONIC)
	    digMod = DigitalModule.getInstance(ULTRASONIC_SLOT);
	    i2c = digMod.getI2C(ULTRASONIC_ADDRESS);
	    timer = new Timer();
	    controlLoop = new java.util.Timer();
	    if (i2c.addressOnly())
		NRGLCD.println4("ERR: No Ultrasonic!");
		Debug.println(Debug.FATAL_EXCEPTIONS, "ERROR: Could not find Ultrasonic.");
	    //Range: Three meters.
	    i2c.write(0x02, 0x46);
	    //Analogue Gain: 317
	    i2c.write(0x01, 0x18);
	    period = .05;
	    setDist();
     * Ends the control loop.
    public void free()
	controlLoop.cancel();
	controlLoop = null;
    public int getDist()
	return dist;
    public boolean getWriteFail()
	return writeFail;
    //gets distance
    private void setDist()
	byte high, low;
	try
	    //setting range to centimeters
	    if (i2c.write(0x00, 0x51))
		writeFail = true;
		Debug.println(Debug.ULTRASONIC, "Attemted write to ultrasonic, failed.");
	    else
		writeFail = false;
		Debug.println(Debug.ULTRASONIC, "Wrote to ultrasonic, began rangefinding in centimeters.");
		timer.reset();
		timer.start();
		try
		    boolean done = false;
		    Timer.delay(.065);
		    for (int i = 0; i < 10; i++)
			byte[] buffer = new byte[1];
			if (i2c.read(ECHO_ADDRESS_HIGH, 1, buffer))
			    //Debug.println(Debug.ULTRASONIC, "Attempted read to ultrasonic high, failed.");
			else
			    high = buffer[0];
			    if (i2c.read(ECHO_ADDRESS_LOW, 1, buffer))
				//Debug.println(Debug.ULTRASONIC, "Attempted read to ultrasonic low, failed.");
			    else
				low = buffer[0];
				dist = high * 256 + ((int) low & 0xFF);
				Debug.println(Debug.ULTRASONIC, "Try: " + i + " Time: " + timer.get() + " High: " + high + " Low: " + low + " Dist: " + dist);
				done = true;
			if (done)
			    break;
			//Debug.println(Debug.ULTRASONIC, "Try "+i+" failed.");
			if (i == 9)
			    Debug.println(Debug.ULTRASONIC, "TRIED 10 TIMES!");
			Timer.delay(.02);
		catch (Exception e)
		    Debug.println(Debug.FATAL_EXCEPTIONS, "Attempt to read ultrasonic caused a fatal exception.");
	catch (Exception e)
	    Debug.println(Debug.FATAL_EXCEPTIONS, "Attempt to write to ultrasonic caused a fatal exception");
	//Schedule next loop.
	controlLoop.schedule(new UltrasonicTask(this), (long) (period * 1000));
And even after you know your distance, it's really not so easy to just drive directly at it. What type of drive train are you running? If it's a tank drive - does your robot drive straight if you just feed the same power to left and right motors?
