Go to Post Canadian teams would definitely be able to give some of the "big boys" a run for their money. Despite the fact that their money is worth more than ours... =) - Karthik [more]
Unread 10-02-2014, 00:57
philso philso is offline
FRC #2587
PDB question for Inspectors
This is a question for those of you who work as inspectors.
We have a tightly packed electronics panel. There is about a one inch gap between the power distribution board and a line of 4-5 motor controllers installed on each side. We have a bundle of PWM wires running through that gap that can obscure the LED's along the sides of the PDB from being viewed directly. If one of the LED's is on, we can still see a red glow between the wires. Would this pass inspection or should we re-route the wires now while we still can? The power wires to and from the motor controllers and the snap-action breakers are all clearly visible.
I can post a picture tomorrow evening if necessary.
Thanks.
Phil
Unread 10-02-2014, 01:13
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: PDB question for Inspectors
Visibility of the red 'open breaker' lights is not regulated by any rule, nor is it a inspection item. As long as the PDB (including status lights and 24v/12v/5v supply headers) and breakers are easily visible you're fine from a rules/inspection standpoint.
Unread 10-02-2014, 22:13
DonRotolo's Avatar
Back to humble
FRC #0832
I agree, we are inspecting for circuit breaker and wire visibility, not those little LEDs.
Of course, imagine you need to replace a motor controller: Can you? If not, you may benefit from some reconfiguration, otherwise you should be OK.
Unread 11-02-2014, 07:29
Phil,
The edge mounted LEDs are really bright and not a problem if you can't see them direct. Please post a picture, we love to look into other robots.
Unread 12-02-2014, 00:52
FRC #2587
Thanks for the feedback. We will probably add some cable ties to make the LED's more visible.
I just posted a link to some photos in another thread.
http://www.chiefdelphi.com/forums/sh...d.php?t=126291
Unread 12-02-2014, 07:45
Phil,
Those photos don't look bad to me.
Unread 12-02-2014, 13:46
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
For PWM and other signal routing, I suggest avoiding the neighborhood of high current DC wiring (powerful motors, compressor), or crossing that wiring at right angles. You won't get dinged for that at inspection, but it improves the reliability of your robot.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 12-02-2014, 14:30
AKA: Steve Peterson
One more thing: throw one of these in your toolbox.
http://www.amazon.com/s/ref=nb_sb_ss...ental%20mirror
Unread 12-02-2014, 14:34
FRC #2587
While it is best to not mix signal and power wiring, it is difficult, if not impossible to do when wiring devices that have both so one has to follow some common practices used in the Electrical and Electronics industries.
The least coupling that one can get between two wires IS when they cross at right angles. What one should avoid is running "sensitive" wires susceptible to external interference PARALLEL to wires likely to emit interference.
