Go to Post I didn't know that Dean Kamen had 3 arms. - kevin.li.rit [more]
Unread 11-02-2014, 08:18
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: Milling Machine Question
Excess chip loading:
1) number of teeth engaged with the cut to large.
2) volume of metal per chip too large (excess depth per pass & feed per tooth)
3) strength of metal per # of simultaneous flutes cutting to great.
4) diameter of cutter too large for spindle motor torque
5) cutter teeth too dull or damaged
6) profile of cutter giving too much linear contact with teeth
Other:
7) if a variable speed spindle motor, running at too low of an RPM
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 11-02-2014, 08:28
Mr. Mike's Avatar
Mr. Mike Mr. Mike is offline
FRC #3138 (Innovators)
Mr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to all
Other:
8) If you are running a manual mill on a static phase converter it loses 1/3 of the hourse power.
