Go to Post Team handbooks - they are like safety glasses... they seem stupid and a pain to wear, and they make it harder to see... but they seem important about 1 msec after a flaming hunk on metal bounces off them. - Not2B [more]
Unread 10-02-2014, 18:59
nrogals nrogals is offline
None #3173
nrogals is on a distinguished road
Supporting 40lbs Arm with Motor?
Hello Everyone,
Our team is looking to put a long rage shooter and acquisition unit on a single arm. Both units will weigh about 20lbs. The torque on the motor will be near 70-80 foot pounds.
Can a Mini CIM and a multiple stage gear box hold the arm up via friction in the gear box. If not, is there a method for running the motor with a certain voltage pattern such that it holds the arm and will not pull a sufficient amount of power away from the drive train.(Electric Break)
If not, at last resort, does anyone have any suggestions to apply a mechanical break to the motor shaft.
Thanks!!!!!
Unread 10-02-2014, 19:03
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Supporting 40lbs Arm with Motor?
How is the motor coupled with your arm? 80ft lbs is a lot of internal friction.
Perhaps you can add counterweights, springs or use a screw mechanism to rotate your arm.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 10-02-2014, 19:07
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
If possible try to counterweight or otherwise balance the arm so the motor is only moving the arm up and down and you are not stalling the motor to hold the arm in position.
Given the numbers from your post this isn't going to be an easy solution, you may wish to look at gas shocks and other more robust methods of accomplishing this.
Good luck!
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 10-02-2014, 20:59
inquiryteacher inquiryteacher is offline
FRC #3173
inquiryteacher has much to be proud ofinquiryteacher has much to be proud ofinquiryteacher has much to be proud ofinquiryteacher has much to be proud ofinquiryteacher has much to be proud ofinquiryteacher has much to be proud ofinquiryteacher has much to be proud ofinquiryteacher has much to be proud of
Why not simply spring load the rear of your shooter so that it takes some of the load off from the motor? Gravity will assist on the way down to acquire, and the spring will assist to get you started back up.
Unread 10-02-2014, 21:04
yash101 yash101 is offline
AKA: null
Worm gear drive?
Unread 10-02-2014, 21:52
teachsail's Avatar
teachsail teachsail is offline
AKA: Daniel Riedinger
FRC #2584 (Reseda Regents Robotics)
teachsail is a jewel in the roughteachsail is a jewel in the roughteachsail is a jewel in the rough
The elastic is a good idea and the simplest. You could also drive the arm with a screw. It will give you your mechanical advantage with out back driving. Use a Love Joy between your screw and gearbox output shaft.
http://www.mcmaster.com/#spider-couplings/=qn2jdu
http://www.mcmaster.com/#acme-precis...screws/=qn2k15
Unread 10-02-2014, 21:55
mikemat mikemat is offline
mikemat has a spectacular aura aboutmikemat has a spectacular aura aboutmikemat has a spectacular aura about
I'd highly recommend counterbalancing the arm somehow, either with weight or with some form of spring. If you can't, then you could look into a worm gear to hold the arm in position. Weather a multi-stage gearbox can hold it is entirely dependent on the specifics of said gearbox.
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
we have a similar weight shooter/arm. Ours is counterbalanced with a gas lift spring like the ones used on car hoods. The arm itself is powered by a banebots 256:1 gearbox connected to a 18 tooth Gates pulley driving a Gate belt around a 50 tooth pulley welded to the arm. Works well .
Unread 10-02-2014, 21:58
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
If the arm only rotates one direction, it may be possible to use a ratchet and pawl.
If not +1 on the spring loading. 1" diameter surgical tubing does wonders.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 10-02-2014, 22:25
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Some of you may remember Team Driven's Pizza Box from GKC, Razorback and World Champs, the box weighed 40 or so pounds and we had to use a worm gear box and dual miniCIMs with a 32:1 reduction to lift it. This is a very challenging feat to accomplish. You will not be able to do it with all but the toughest of planetaries with a massive reduction. A banebots 256:1 P60 is only rated at 36 (IIRC) foot pounds of torque and you just double that. Worm gear with a substantial reduction is the way to go.
Worm gears can be ordered to be back drive proof, but beware, cast iron gears can (and will) shatter if they take a shock load (like a sudden hit from your arm being rammed). We had to custom make bronze gears to alleviate this fault
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 11-02-2014, 07:36
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
Originally Posted by nrogals View Post
Hello Everyone,
Thanks!!!!!
Well to answer your question...yes you can have the motors on brake where it switches directions rapidly so that you cannot back drive. I don't really know your situation, but I know window motors have an internal locking mechanism (to stop thiefs).
We have a RS-775 12 attached to a 1:100 reduction and we mounted a sprocket on the end of our winch. There is then a pin that inserts in the teeth/grooves of the sprocket when we want the motor to brake (not back drive). The 775 will also be on brake when the winch lock in engaged.
Keegan Harrington
Truck Town Thunder
2013-2014: Mechanical Design
"Infinity: you empty out all of the coffee and there is still more orange juice"
Unread 11-02-2014, 08:02
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Check out the KOP page and Vulcan Springs. Their constant force springs are an easy way to add a counter balance and can significantly reduce the load you need to break.
BTW They respond quickly and even give you free shipping, great company!
Unread 11-02-2014, 09:24
Would you please explain what you meant by this?
Unread 11-02-2014, 09:29
Imaginary Friend
AKA: Kevin Li
Team Role: Student
I think he meant you can an stop the movement of an arm or other mechanism by running the motor opposite to the current rotation.
Kevin Li
596 - Sciclones
Unread 11-02-2014, 09:33
It sounds like what you are describing is for your launch catapult arm. If so, how do you disengage the gearbox from the winch when you fire it?
