Go to Post If you don't have a butt to fill that seat, you don't need it. When the butt arrives, we'll make room. - DonRotolo [more]
Unread 10-02-2014, 22:03
harryji369's Avatar
harryji369 harryji369 is offline
Captian
AKA: Harry Indrataher
FRC #0369 (High Voltage)
harryji369 will become famous soon enough
Signal isssue
Our new robot is all wired up however our motor controllers are not reviving any signal aside from one which is blinking red. we are using the Talons motor controller for the drive and two victors. we tried everything that came to mind Crio imaging, Digital side cart, code rewrite. Please help us i wanna go home, they wont let me leave
Unread 10-02-2014, 22:27
Re: Signal isssue
What kind of motor speed controller is blinking red? Talons blink either red or green when being driven at less than full power.
You are enabling the robot before deciding that the Talons and/or Victors aren't getting signal, right?
Unread 10-02-2014, 22:32
harryji369's Avatar
Captian
Re: Signal isssue
we are using the talons for the drive and victors for the manipulator and we did enable the robot and it is one of the talons that is blinking red
Unread 10-02-2014, 23:04
mega900997's Avatar
mega900997 mega900997 is offline
FRC #0263 (Sachem Aftershock)
mega900997 is on a distinguished road
Re: Signal isssue
Few Baseline Questions to ask:
1)What language are you using?
2)Are the lights on the victors solid when you enable it?
3)Is the Digital Sidecar receiving power?
4)Are the PWM wires plugged into the correct slots?
5)Also with whatever you are using to control the robot(controller/gamepad/joystick etc.), is it numbered as in when you open up the driverstation and go to the status/diagnostic page(don't remember which one offhand) is that controller in slot 1(or whichever value you are setting your controller as in the code) in the table on the right hand side?
(I can't say anything about Talons, I have not worked with them.)
If the Victor lights are solid when the robot is enabled, then it is receiving a signal and its a problem where the value you are sending from your controller is not setting the victor values.
Suffield Shakedown Winners & Most Points Scored
South Florida Regional 6th Seed, #5 Alliance Captains, Regional Winners w/ 2383 & 386, Innovation in Control Award
NY Tech Valley Regional 5th Seed, QF, Excellence in Engineering Award
SBPLI Long Island Regional 4th Seed, Finalists
Hopper Division 14th Seed, QF
Unread 10-02-2014, 23:08
harryji369's Avatar
Captian
Re: Signal isssue
we get no solid lights at all, all wiring has been checked joysticks are being seen by the driverstation and we are using c++.
Unread 11-02-2014, 06:29
mega900997's Avatar
Re: Signal isssue
Then it can be a problem with your code. Are you initializing the Victors/Talons correctly and and setting a value corresponding to the controller input value? Print out what you are sending to the motors and what the motors are receiving, or just print out all necessary info.(Printf helps alot with debugging).
ex:
Victor *DriveMotor;
DriveMotor = new Victor(1);
DriveMotor->Set(1.0);//sets Victor to drive forward at full speed
(This is how I do it in my code)
Unread 11-02-2014, 09:26
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Signal isssue
You need to calibrate the Talon, press and hold the small button on the Talon labeled something along the lines of Calibrate and send the motor 1.0 and then -1.0 and then let go of the Calibrate button. The easiest way to do it is to set the Talon's speed straight to a joystick axis output. More information here: http://www.crosstheroadelectronics.c...Manual_1_3.pdf on page 7.
We had the exact same issue initially and it was solved by creating a simple program that just sends the joystick value to the motor and completing the process for each Talon. Afterwards they worked perfectly.
Unread 11-02-2014, 09:32
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: Signal isssue
Are your cRIO modules in the correct places?
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
