Go to Post You can lead a horse to water but you can't make it drink. Our job is to make the horse thirsty. - Andrew Schreiber [more]
Unread 11-02-2014, 10:11
Dackarobot Dackarobot is offline
FRC #2905
Dackarobot is an unknown quantity at this point
Motors not moving
hi,
the motors and Victors were all working fine before we installed them onto the robot. But now, none of them are moving. we tried everything like disconnecting all the limit switches, ultrasonic sensors and motors from the sidecar and the power distribution board except one Victor. We tried connecting the PWM cables the other way. There is 12V on the left side of Victor and its fan is rotating but there is no voltage on the right side of it. Can you give any recommendations?
begin.vi
teleop.vi
On the Diagnostics page of the dashboard, we see the following error messages about the camera although we did not enable vision.
Warning <Code> 44002 occurred at Ping Results:  link-bad,  DS radio(.4)-bad,  robot radio(.1)-GOOD,  cRIO(.2)-GOOD,  FMS-bad Driver Station
<time>2/11/2014 5:03:46 PM<unique#>72
FRC:  Driver Station ping status has changed.
ERROR <Code> -44003 occurred at WPI_CameraIssue HTTP Request with Authentication.vi>>WPI_CameraIssue Get.vi>>WPI_CameraSet Image Appearance Property.vi>>WPI_CameraSet Enum Appearance Property.vi>>WPI_CameraSet Image Size.vi>>Vision Processing.vi>>Robot Main.vi
<time>00:02:57 01/01/1970
FRC:  Operation failed due to a communication failure with the camera.
ERROR <Code> -44003 occurred at WPI_CameraIssue HTTP Request with Authentication.vi>>WPI_CameraIssue Get.vi>>WPI_CameraGet Image Appearance Property.vi>>WPI_CameraGet Color Enable.vi>>WPI_Camera Registry.vi>>WPI_CameraOpen.vi>>Vision Processing.vi>>Robot Main.vi
<time>00:02:55 01/01/1970
Warning <Code> 44003 occurred at Driver Station
<time>2/11/2014 4:58:55 PM<unique#>71
FRC:  No robot code is currently running.
WARNING <Code> 44007 occurred at FRC_NetworkCommunications <secondsSinceReboot> 3.391
FRC:  Time since robot boot.
<time>2/11/2014 4:56:20 PM<unique#>70
Warning <Code> 44002 occurred at Ping Results:  link-bad,  DS radio(.4)-bad,  robot radio(.1)-bad,  cRIO(.2)-bad,  FMS-bad Driver Station
<time>2/11/2014 4:56:19 PM<unique#>69
Warning <Code> 44002 occurred at Ping Results:  link-bad,  DS radio(.4)-bad,  robot radio(.1)-bad,  cRIO(.2)-GOOD,  FMS-bad Driver Station
<time>2/11/2014 4:56:08 PM<unique#>68
<time>2/11/2014 4:47:46 PM<unique#>67
Warning <Code> 44004 occurred at Driver Station
<time>2/11/2014 4:47:43 PM<unique#>66
FRC:  The Driver Station has lost communication with the robot.
