Go to Post Overall, I thought FIRST did a great job with the rules this year - very simple and very clear for the most part. However, something is always going to fall through the cracks (and I don't mean that in a bad way - people need to know that it's practically impossible to do something perfectly). - Chris Hibner [more]
Unread 11-02-2014, 12:51
Re: Multithreading on Java
Originally Posted by BigJ View Post
Commands can be running "simultaneously" as long as they don't require writing data to the same Subsystems.
That statement taken at face value would seem to allow the following:
Command A requires only Subsystem B and takes 1ms to complete.
Command X requires only Subsystem Y and takes 3 seconds to complete
Since Command A and Command X don't require writing data to the same Subsystems, they can be running simultaneously
My question is, how does the CommandBased model implement this, if not by preemptive time-slicing.
Posts 6 and 8, and post 10 if I interpreted it correctly, would answer that question.
