Go to Post As long as they're not destroying each other, LET THE TEAMS PLAY! - Travis Hoffman [more]
Unread 10-02-2014, 15:52
1757 1757 is offline
FRC #1757
1757 is an unknown quantity at this point
Multithreading on Java
I understand that there's a Task class in C++, but how do I multithread in Java? I can't find any Java counterpart to the C++ class. Thank you
Unread 10-02-2014, 16:31
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: Multithreading on Java
http://docs.oracle.com/javase/tutori...runthread.html
-Borna Emami
Team 0x27
Unread 11-02-2014, 09:09
FRC #1757
okay thanks, I didn't think to try that because it's not native to the cRIO
Unread 11-02-2014, 09:40
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
The Command Based programming model available through the WPILib is a good way to achieve concurrency in your software.
http://wpilib.screenstepslive.com/s/...ed-programming
Unread 11-02-2014, 10:19
Quoting from the linked document:
Notice that the apparent concurrent execution is done without the use of threads or tasks
... so how does that work, exactly?
Unread 11-02-2014, 10:47
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
the Scheduler when using command based maintains it's own list of active commands, and (when a DS packet arrives) calls their execute() and isFinished() methods for every command on the list (sequentially).
No preemptive scheduling here, everyone's execute() and isFinished() has to play nice....
Unread 11-02-2014, 11:02
So it's still up to the programmer to use something like a state machine or perhaps yield() statements to achieve this? Or am I misunderstanding this?
Unread 11-02-2014, 11:08
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Each command needs to finish its execute command quickly, any waits or long executions will cause everything else to come to a halt until it is finished.
Unread 11-02-2014, 11:22
So how does the command based programming model help the novice programmer achieve concurrency, like for example when they want to wait for 3 seconds after performing one action before performing the next action, without stalling their processing of the 20ms DS packets ?
Please note: this is not veiled criticism of the command based model; I'm just trying to untangle things.
Unread 11-02-2014, 11:28
Flywheel Police
You can create something called a CommandGroup which will run one command after another in a series (much like a series in labview), the Command Based API has a WaitCommand provided which will act as a wait period in seconds. It can also be done in a normal command by noting the initial time the command was started and basing actions off of the time since the start time.
Unread 11-02-2014, 12:21
The way you worded that doesn't clearly answer my question.
Let me try re-wording it:
You can create something called a CommandGroup which contains a sequence of commands, intended to be executed one after another. The scheduler will queue the first of those commands, then queue the next command when the previous one has completed, and so on until all the commands in the group have been so queued (and therefore run in sequence). The Command Based API has a WaitCommand. The WaitCommand is not queued. Rather, when the scheduler encounters a WaitCommand in a CommandGroup, the scheduler does not queue the command following the WaitCommand until the specified time has expired.
I have no idea if the above description is an accurate account of what the Command Based implementation actually does, but is that what you meant?
That's a sort of state machine, with time being the state variable.
Unread 11-02-2014, 12:30
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Commands can be running "simultaneously" as long as they don't require writing data to the same Subsystems. CommandGroups are used mainly for automation (ex. I might have a ShootAndReload command group that releases my winch, then proceeds to roll it back up again immediately by calling the different Commands in a certain configuration). You can add Commands to a CommandGroup to run in sequence or parallel.
Unread 11-02-2014, 12:51
That statement taken at face value would seem to allow the following:
Command A requires only Subsystem B and takes 1ms to complete.
Command X requires only Subsystem Y and takes 3 seconds to complete
Since Command A and Command X don't require writing data to the same Subsystems, they can be running simultaneously
My question is, how does the CommandBased model implement this, if not by preemptive time-slicing.
Posts 6 and 8, and post 10 if I interpreted it correctly, would answer that question.
Unread 11-02-2014, 13:01
AKA: Josh P.
They aren't actually running simultaneously. I'm not sure if I'm interpreting "preemptive time slicing" correctly, but any Command-Based program could be written in the IterativeRobot style with a large number of if statements . They're all running on one thread as I understand it, and I am not sure you have any guarantee to the order they run in. That is why Commands can declare that they require exclusive access to a Subsystem to tell other Commands that they will be writing data to it.
Both commands will run the execute() method in their class each robot loop (usually 20ms) until their isFinished() check (also run each loop) returns true. The Scheduler takes care of all the behind-the-scenes work of maintaining command life-cycles.
Unread 11-02-2014, 13:10
A command is a state machine. The scheduler handles transitioning between states. The states are listed below:
initialize
execute
end
interrupted
The user provides the code that goes in those methods. There is a fifth method (isFinished()) that allows the scheduler to know when to transition from execute to end.
The normal flow is from initialize to execute to end. The scheduler handles interrupting, if a new command is scheduled that requires the same subsystem.
A CommandGroup allows multiple commands to be scheduled sequentially or in parallel (being in parallel requires that they don't require the same subsystem).
The only times we have had to add an explicit state machine inside a command, is when there is decision logic that needs to go backwards in states. In our case, that's been relatively rare.
The scheduler is entirely cooperative. It depends on the commands methods executing quickly and returning. If the user puts an explicit Timer.wait() in a command, it breaks the execution model. The user can either use a WaitCommand, or check a timer in the isFinished method, or implement their own state machine. We've done all 3.
