Go to Post Don't tell the rookies to "not touch the robot", show them how to work safely. - Andy Baker [more]
Unread 11-02-2014, 09:34
Re: Supporting 40lbs Arm with Motor?
Originally Posted by kevin.li.rit View Post
I think he meant you can an stop the movement of an arm or other mechanism by running the motor opposite to the current rotation.
Let's wait and see.
Unread 11-02-2014, 09:43
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
Would you please explain what you meant by this?
http://www.chiefdelphi.com/forums/sh...80&postcount=3
Rather than switching the direction, it is shorting across the terminals. Sorry for the misunderstanding.
It sounds like what you are describing is for your launch catapult arm. If so, how do you disengage the gearbox from the winch when you fire it?
Well our system is a little bit different. We have a transmission as described that does not shift. That transmission pulls back the winch to any desired start point and we have a brake system that holds the catapult in position while the winch unwinds to the desired hard stop length. Then the lock that I described in the previous post comes in. We did this to eliminate the need for a two speed transmission.
Keegan Harrington
Truck Town Thunder
2013-2014: Mechanical Design
"Infinity: you empty out all of the coffee and there is still more orange juice"
Unread 11-02-2014, 10:06
So when you said in your previous post that "we mounted a sprocket on the end of our winch. There is then a pin that inserts in the teeth/grooves of the sprocket" you did not mean that the sprocket was connected to the winch, but rather to the arm? So the winch can unwind while the arm is locked in place by the pin and sprocket?
...the winch unwinds to the desired hard stop length.
Are you saying that the winch acts as as the hard stop? Is the impact load transferred to the gearbox?
Unread 11-02-2014, 10:11
TheKeeg's Avatar
No. The sprocket is mounted on the winch. There are two brakes/locks. One on the winch and one on the catapult. The Winch lock with the pin and sprocket engage whenever the winch is not moving so that it cannot back drive. When the catapult is locked in position, the winch can unwind. The load is on the axle, but it is very supported.
Keegan Harrington
Truck Town Thunder
Unread 11-02-2014, 10:23
Ah. There's the missing puzzle piece. What does the catapult lock look like, and how do you release it?
Unread 11-02-2014, 10:41
TheKeeg's Avatar
I cannot release a picture yet, but we drew inspiration from one way bearings. The brakes use the rotation of the catapult to their advantage, and with a little mechanical advantage and pneumatics, they are easy to release.
Keegan Harrington
Truck Town Thunder
Unread 11-02-2014, 11:05
I cannot release a picture yet...
When and if you are free to do so, I think it would be most interesting to see what your team has done
Unread 11-02-2014, 12:29
TheKeeg's Avatar
Will do.
Keegan Harrington
Truck Town Thunder
Unread 11-02-2014, 13:04
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Originally Posted by nrogals View Post
Both units will weigh about 20lbs.
Are you saying that both of them together will weigh 20 pounds or that they each weigh 20 and together they are 40?
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Uriah Uriah is offline
FRC #4531 (STEMpunk)
Uriah is an unknown quantity at this point
Originally Posted by NOV8R View Post
we have a similar weight shooter/arm. Ours is counterbalanced with a gas lift spring like the ones used on car hoods. The arm itself is powered by a banebots 256:1 gearbox connected to a 18 tooth Gates pulley driving a Gate belt around a 50 tooth pulley welded to the arm. Works well .
256:1 Wowza.
We have a similar system, and are using a 49.4:1 gear box with a mix of pnuematics. We did have problems with friction, but some lithium grease and letting the system wear in helped.
2010 - 2012: CAD Captain - Droid Rage #3381
2010: Rookie All Stars - Wisconsin Regional
2011: Imagery Award - Wisconsin Regional
2011: Safety Pin - Wisconsin Regional
2012: Judges Award - Lake Superior Regional
2013 - Present: Mentor - STEMpunk #4531
2013: Rookie All Stars - Wisconsin Regional
2013: Highest Seeded Rookie - Wisconsin Regional
2014: Engineering Inspiration Award - Northern Lights Regional
2014: Imagery Award - Wisconsin Regional
Unread 12-02-2014, 11:44
TheKeeg's Avatar
This is what the brakes look like:
http://www.chiefdelphi.com/media/photos/39541?
Keegan Harrington
Truck Town Thunder
Unread 12-02-2014, 11:53
Great idea !
Is the brake spring-loaded in the brake_on (or brake_off) position?
Or is the cylinder powered in both directions?
Unread 12-02-2014, 11:58
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Westinghouse would be proud.
Unread 12-02-2014, 12:02
TheKeeg's Avatar
Great idea !
It is a dual-acting cylinder. In the picture the brakes are not engaged.
Keegan Harrington
Truck Town Thunder
