Go to Post Students learn from, are inspired by, and emulate their mentors. A team with a solid mentor base helps to create a productive, inspired, and ultimately successful group of students. - Jared Russell [more]
Unread 11-02-2014, 15:37
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
I'm not a programmer but here's a link related to pneumatic wiring if the problem is with electronics. My team was wondering how to wire the solenoid to the solenoid breakout. I guess your post confirmed it was a wago connector we needed.
http://www.chiefdelphi.com/forums/sh...d.php?t=125707
Unread 11-02-2014, 15:50
Oblarg Oblarg is online now
AKA: Eli Barnett
Re: Still Having Pneumatics Problems
Caveat: While I know java, I'm not a robot programmer so I might be completely wrong about this.
That said, it seems like a really bad idea to use while loops in that way, as it makes it impossible for any code to execute at the same time as your solenoid commands. Moreover, since there is always one of your conditions that is true, you will in general never be able to execute any code other than that specific set of solenoid commands. Using different buttons for forward and backward commands on a double solenoid seems bad practice, too, without some sort of way to handle the case where both buttons are pressed at once, though I do not know off the top of my head what the behavior would be in this situation without something explicitly handling it in code, I could imagine it might be unfortunate (ironically, the fact that you're going to get caught in a loop with your given code handles this problem by itself as the forward and backward commands can't execute simultaneously, but upon revising it it'd rear its head).
"The breakfast of champions!"
Unread 11-02-2014, 15:55
magnets's Avatar
magnets magnets is offline
That said, it seems like a really bad idea to use while loops in that way, as it makes it impossible for any code to execute at the same time as your solenoid commands. Moreover, since there is always one of your conditions that is true, you will in general never be able to execute any code other than that specific set of solenoid commands. Using different buttons for forward and backward commands on a double solenoid seems bad practice, too, without some sort of way to handle the case where both buttons are pressed at once, though I do not know off the top of my head what the behavior would be in this situation without something explicitly handling it in code, but I could imagine it might be unfortunate (ironically, the fact that you're going to get caught in a loop with your given code handles this problem by itself as the forward and backward commands can't execute simultaneously, but upon revising it it'd rear its head).
You're right. The robot program is one big loop. To get it to work, you'll need to change those while loops to if/then/else.
