Go to Post Lighten it up a little to bring it in under the 120 pound weight limit, and I think you will have something there! - dlavery [more]
Unread 11-02-2014, 15:31
EliStevens12 EliStevens12 is offline
FRC #4925
EliStevens12 has a spectacular aura aboutEliStevens12 has a spectacular aura about
Orange Light
My FRC team was wondering if there was any specification to where the orange light needed to be, we were wondering if it needed to be on some type of post, or it just had to be visible, or if there are no specification about the orange light at all. Any help would be greatly appreciated, Thank You.
Unread 11-02-2014, 15:37
jdaming jdaming is offline
jdaming is on a distinguished road
Re: Orange Light
Please see R63. Posted here for convenience:
R63
ROBOTS must use at least one (1) diagnostic ROBOT Signal Light (RSL) (P/N: 855PB-B12ME522).
Any RSL must be:
mounted on the ROBOT such that it is easily visible while standing three (3) ft in front of the ROBOT,
connected to the “RSL” supply terminals on a Digital Sidecar that is connected to an NI 9403 module in Slot 2 of the cRIO, and
wired for solid light operation, by placing a jumper between the “La” and “Lb” terminals on the light per Figure 4-13.
See the 2014 ROBOT Data Diagram on the KOP website and the item bulletin for connection details.
Figure 4-13: Jumper on RSL
Unread 11-02-2014, 15:38
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Orange Light
Manual has this to say:
Any RSL must be:
So, in a practical sense, it mostly needs to be visible for field personnel in case your robot is having a connection/code/power issue, or similar.
Also, you can have more than one.
Ninja'd
Unread 11-02-2014, 15:41
FRC #4925
Re: Orange Light
Thanks for the help.
Unread 11-02-2014, 15:42
Re: Orange Light
Eli,
To add to those who already have posted the rule, the RSL flashes codes that help identify what state your robot is in and what might be an issue when on the field. Having it visible from the sides of the field helps us determine issues on your robot.
